Hey guys so recently my headlights began to mess up. I resorted to changing the stalk switch and then change the motor.
after changing the motor, both headlights went up fine, yet the one with the changed motor wasnt level with the perfectly working pop up light.
So after a spirited drive, my car had a new issue which is now hilarious and frustrating as eff.
As the title of the thread says; one headlight goes up and the other goes down.
this happens when flick the lights on and even the pop up button. Both sides seems to think its off but one is clearly up and the same story when lights are on, one is down. There is also a bit of a clunking noise as the light thats problematic is going down.
the course of action i took was to disconnect the mechanism that you can screw the cap to adjust the headlight levels. And then put it back while the lights are in the off position... this did not work.
Another course of action i took was removing the relays in the fuse box below the intake. Now... this did not work also.
So i am now here asking my dear nissan friends if they know the solution i could try or even to go an auto electrician who are knowledgeable about 180’s.
Your help is hugely appreciated!
and if someone tells me to buy abflug lights, I honestly would rn. Ball ache af!!!
    • I steam cleaned my near new set of volk gtc wheels 14 years ago and farrkkked them lol. The clear coat cracked like spider webbing in several areas. Lesson learnt don't do that. 😭
    • If you don't touch the CAS, then you're fine.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
