All,
My r34 had an engine light on and it seemed the o2 sensor was dead as there was no input on my apexi turbo timer on A/F.
in the uk the cost of O2 sensor was around £150 so after long search of forums, I ended up buying one for nissan micra 1.3 1998 and fitted after changing the wiring on the O2 sensor so it could connected to the ecu connector.
here is another example of it in the uk confirming the o2 sensor works on Micra as well as Skyline
https://www.ebay.co.uk/itm/OXYGEN-OXY-O2-SENSOR-for-NISSAN-SKYLINE-R33-RB25-SERIES-1-Series-2-RB25DET-/301405627170
The car was ok but still felt as it was running rich so I changed the turbo boost pressure sensor and still seems to be mis firing .
The Boost pressure sensor item number was PS660-1 Hitachi boost sensor which match nissan navara 2.5 td 2002-2005.
It costs £80 from a distributer in the UK if bought for skyline so i bought it for nissan navara 2.5 td 2002 and it was half the price and exact same part number.
question is, if the part number is the same, should it produce a same output regardless of car it was on ?
Could I have messed up by installed an O2 sensor from another car? I suppose the reading will be the same so it shouldn't matter.
Edited by drifter17a
https://www.sau.com.au/forums/topic/475923-r34-o2-sensor/
O2 sensor is likely to be fine.  Hell, 20 years ago I put one from a Ford onto my RB20 because it was the most cost effective way to do it.  As long as the sensor is the same tech, it's fine.  But where they are not the same, it's not possible.  The sensors on Neos are quite different from the older ones, for example.
The boost sensor, if it has the same part number, will be the same.  Couldn't be different.  Couldn't cause your problem, unless you damaged/stretched a loom or pin or something while changing it.  Also, they are completely unlikely to need to be replaced at any time, so you wasted your time and money there.
https://www.sau.com.au/forums/topic/475923-r34-o2-sensor/#findComment-7897029
On 1/24/2019 at 5:37 AM, Rusty Nuts said:
Then its the same part, can't believe this question, you are kidding right.
trying to narrow down the issue by eliminating anything that could cause it .
I think it is due to having blow off valve so AFM is accounting for air that is getting released hence running rich and missing every  now and then. does this make sense to you guys ?
https://www.sau.com.au/forums/topic/475923-r34-o2-sensor/#findComment-7897240
If your BOV is external venting and you have an airflow meter, then the setup is wrong and you need to get rid of the BOV and/or replace it with a recirculating BOV.  This is not rocket surgery.  These lessons were learnt in the 1990s and are excruciatingly well documented on this and every other such site.
https://www.sau.com.au/forums/topic/475923-r34-o2-sensor/#findComment-7897259
    • Probably being in IT for 2 decades, and spending my time documenting trees worth of shit and also being on the receiving end has taught me a thing or two.
    • Why's that depressing, wouldn't it be able to go indefinitely until the battery gets old and craps itself? If it's constantly on charge/maintaining charge, won't that keep the battery healthy?
    • One of my concerns initially was if something catches fire somehow.
    • I think I know what you mean. I saw the same thing a while back, I think either the images on the website were wrong or the model was slightly updated. It was weird when I first looked at it, same model but different looking unit.
    • At work we've got a smaller version of the Projecta that Duncan posted above. At home, I have an ALDI trickle charger. Ive had it for about 8 years now. Only issue with it, it's a smart charger, so if the battery is dead, it won't bring it up, but I have a variable power supply that I limit current on, and set to a max of 14.4v. once it starts charging up, I put the aldi unit on and remove the variable PSU. ALDI one will do 12v, or 6v, then has mode for "car" "motorbike", and "snow". With car or motorbike more for its internal workings, and snow is the trickle mode. I have a battery in the garage that lives on this charger for about the last 18 months now on Snow mode. When I need to charge my other batteries (eg, ones that have died in a car), I get them started and then run it on car mode. Voltage is always sitting really nice, and hasn't killed a battery yet. that charger isn't good for things like Lithium batteries etc, I'd only use it on Lead Acid.
