All,
My r34 had an engine light on and it seemed the o2 sensor was dead as there was no input on my apexi turbo timer on A/F.
in the uk the cost of O2 sensor was around £150 so after long search of forums, I ended up buying one for nissan micra 1.3 1998 and fitted after changing the wiring on the O2 sensor so it could connected to the ecu connector.
here is another example of it in the uk confirming the o2 sensor works on Micra as well as Skyline
https://www.ebay.co.uk/itm/OXYGEN-OXY-O2-SENSOR-for-NISSAN-SKYLINE-R33-RB25-SERIES-1-Series-2-RB25DET-/301405627170
The car was ok but still felt as it was running rich so I changed the turbo boost pressure sensor and still seems to be mis firing .
The Boost pressure sensor item number was PS660-1 Hitachi boost sensor which match nissan navara 2.5 td 2002-2005.
It costs £80 from a distributer in the UK if bought for skyline so i bought it for nissan navara 2.5 td 2002 and it was half the price and exact same part number.
question is, if the part number is the same, should it produce a same output regardless of car it was on ?
Could I have messed up by installed an O2 sensor from another car? I suppose the reading will be the same so it shouldn't matter.
Edited by drifter17a
https://www.sau.com.au/forums/topic/475923-r34-o2-sensor/
O2 sensor is likely to be fine.  Hell, 20 years ago I put one from a Ford onto my RB20 because it was the most cost effective way to do it.  As long as the sensor is the same tech, it's fine.  But where they are not the same, it's not possible.  The sensors on Neos are quite different from the older ones, for example.
The boost sensor, if it has the same part number, will be the same.  Couldn't be different.  Couldn't cause your problem, unless you damaged/stretched a loom or pin or something while changing it.  Also, they are completely unlikely to need to be replaced at any time, so you wasted your time and money there.
https://www.sau.com.au/forums/topic/475923-r34-o2-sensor/#findComment-7897029
On 1/24/2019 at 5:37 AM, Rusty Nuts said:
Then its the same part, can't believe this question, you are kidding right.
trying to narrow down the issue by eliminating anything that could cause it .
I think it is due to having blow off valve so AFM is accounting for air that is getting released hence running rich and missing every  now and then. does this make sense to you guys ?
https://www.sau.com.au/forums/topic/475923-r34-o2-sensor/#findComment-7897240
If your BOV is external venting and you have an airflow meter, then the setup is wrong and you need to get rid of the BOV and/or replace it with a recirculating BOV.  This is not rocket surgery.  These lessons were learnt in the 1990s and are excruciatingly well documented on this and every other such site.
https://www.sau.com.au/forums/topic/475923-r34-o2-sensor/#findComment-7897259
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
