The car was stolen over 12 months ago now, so time to let go of the last few reminders in the garage...
Instrument Cluster
Cluster was bought off here as the tacho on my original didn't work. Turns out the tacho on this one didn't work either... I ended up getting the original working by having the soldering on the tacho PCB reflowed by a TV repair dude. Worked perfect after that. Could be done on this one too, but hasn't yet. Apart from the tacho its in pretty good nick.   $40
Coil Packs
I went with Splitfires when one of the factory coils gave up. The other five were fine when removed from the car, and have been sitting comfortably in the Spiltfire box ever since. Could be a cheap fix if you have a dud or two.   $40
Exhaust
Turbo back exhaust, including dump and cat.  $50
Happy to post the cluster and coil packs at buyers cost. Exhaust is pick up (Hampton 3188) only for obvious reasons.
Thanks guys.
  • 1 month later...
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
