Hi guys
The name's Keenan. I am from a little place called Cape Town all the way in South Africa.
Thought I'd join the forum after I was lead here while doing some brake upgrade searching.
I drive a Neptune Blue Metallic Nissan N14 hatch (it's called a Sabre 200Gxi here in South Africa) with a SR20DE heart in the bay.
Car is still fairly standard apart from the usual breathing mods.
I've attached some pictures of the old gal and added some specs below.
-63mm exhaust
-RSR Performance header
-poly suspension bushes
-poly engine mountings
-lightened flywheel
-8500rpm crystal on the stock ecu
Next mods to come:
-264/272 degree split cams (already have these in storage just waiting for fitment)
-brake upgrade
-bigger maf (also have this in storage ? )
  • Like 3
https://www.sau.com.au/forums/topic/475951-greetings-from-south-africa/
6 hours ago, PranK said:
Welcome Keenan!
I reckon that would be a blast to drive! I had a CA18DET equipped N13 pulsar at one stage, it was lots of fun!
Thanks PranK
I'm sure it's nothing like the n13 you had though. That must have been a real gokart.
Most n14's here have VE swaps and few DET swaps here and there so I am lagging behind quite a bit ?
2 hours ago, GDZ32 said:
Welcome boet. Lekker CY (now you know why ;P). Glad to see some nice Nissans in CPT and not kust another Citi Golf
Hahaha thanks boet.
Seems you've been away from CPT for far too long now ?
Quite a few lekker cars here now. Citi Golfs are still roaming around now and then though haha
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
