Hi All,
Haven't really been active for a long time on here. Asked some questions on the R33 Owners page on Facebook and got some unhelpful responses so I thought I would try this community again (always been good).
I haven't driven my 33 much at all lately since I bought my fourby but I like to take it out for a bit of a spirited drive on weekends when I get a chance. The last couple of times I've gone out I noticed that for the first 10 minutes or so my 33 makes full boost no worries but progressively over time it struggles to make 1 bar of boost (typically 1.3).
I understand that heat soak is an issue but it has never been this bad since I've owned it.
Car is a R33 with RB25, ATR45SAT Hyper Gear Turbo, Apexi AVCR boost controller, 3" exhaust with Venom cat, Pod filter in an enclosure, Blitz SE return Flow, Haltech ecu, Nismo 740CC injectors.
Things I've checked
- Exhaust manifold studs - 6th cylinder was loose, done them up
- Turbo to manifold studs - one or two were loose, done them up
- Changed all main vacuum lines
- Boost leak tested, no noticeable leaks, sprayed joins etc
- Checked over silicone joiners - no noticeable leaks or splits
I do notice however that the upper section of the intake manifold has what looks like oil on the surface. I checked this when i used the boost leak tester and didn't hear or see anything. When I got back from the last test drive after I thought I fixed the issue, I boost leak tested it just to be sure and didn't hear anything obvious
I always thought that it might be the intake manifold expanding as the engine bay heats up or the exhaust manifold leaking as it heats up.
I thought I would ask here if anyone has any suggestions or personal experience on what I should be looking for with regards to this issue. Any help would be greatly appreciated.
Apologies if this is in the wrong section, please let me know and I can have it moved.
Thanks in advance for helping!
  • Like 1
https://www.sau.com.au/forums/topic/475966-boost-pressure-loss-over-time/
1 minute ago, KiwiRS4T said:
How big is your intercooler? Is hot weather a factor? How do you test for boost leak? Do you make a rig and subject it to say 20 psi and see if it can hold it?
hey mate, i think the specs for the cooler are 620 x 266 x 76mm, I noticed it before Sydney got stupid hot recently but can wait till it cools down again later this week and check again. With the tester I have a nitto connector in a step down plug from bunnings but it doesn't have a gauge on it so I can't see if thats holding pressure. To test I just pressurized it from 5 psi, checked for leaks, 15 psi, checked for leaks, 20 psi checked for leaks by spraying joiners and the manifold
Hope this helps.. might be worth changing my boost leak tester design tho
How hot was it when you drove the car? I find you always need more duty cycle on the EBC during much hotter weather or simply set it up on closed loop which your Haltech could easily manage instead of using the AVCR.
12 hours ago, Dose Pipe Sutututu said:
Random thought, do you want a spare ATR45SAT with ball bearing centre? ?
13 hours ago, iruvyouskyrine said:
What wastegate actuator? Diaphragm may be leaking when hot
Its a Turbosmart replacement, its a possibility for sure but another reason for me to go high mount with external wastegate
I can't rememeber because its happened a few days when I drove it. I would definitely like to test again on a long drive when the 40+ heat pisses off in Sydney. When I asked the tuner i used (going to try someone different next time - cough cough Johnny) they said that they don't use haltech to control boost because it requires adjusting in the ecu which is harder than doing it with a controller.
Now I think of it I could always just up the duty cycle and see how it goes.
I thought it sold already?  I was considering it when I saw you post it lol.
  • Like 1
Still haven't gotten around to checking this out further. Might just find someone to smoke test it while I'm at it in case I've missed something obvious. Might also get an inspection camera under the exhaust manifold and check if its cracked anywhere obvious
On 2/1/2019 at 7:57 AM, Dose Pipe Sutututu said:
Still have it, only sold the manifold and gate
As much as I would seriously love this, I plan on selling the car soon enough. Haven't driven it for a while, the poor thing just gathers dust. The purpose of finding and fixing this issue is to make it more desirable to a buyer lol
Went to see @jmknights93 over the weekend and worked out what part of my problem may be despite hearing no audible leaks.
It looks like the intake manifold gasket is blown out and probably torn and pushing itself out further. I have new gaskets already knowing this day would come so I'll probably change it in the coming days or weeks.
Thanks for everyone's input, I'll make an update when I get around to it.
  • Like 1
  • 1 month later...
Finally  got around to changing the gasket and washers. I found out that not only was the gasket super swollen but one washer was completely missing and pressure wouldn't have been applied in that section of the plenum. Since changing the gasket the cars been running great, idles awesome and no more significant boost pressure loss
Thanks for everyone's input and help :)
  • Like 1
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
