Hey folks
I'm wrecking an r32 gtst manual sedan. Approximately 155000kms. The car has had a front end end and the passenger side has some damage (bonnet, fender, reo, rad support bar etc). The rest of the car is fine although the interior is a bit tired. The car wasn't mine previously, I bought it damaged when I had some ambitious plans but I don't have the time so I'm going to part it out.
The car has the usual bolt-on mods - coilovers, FMIC, turbo-back exhaust, bigger turbo, walbro fuel pump, pod etc
Everything is for sale except the wheels at this stage as I might keep them.
Happy to send specific photos and prices.
Happy to ship Aus-wide.
The following parts have been sold:
Steering wheel
Driver side window regulator
Fuel pump cradle
A pillar trims
Shifter boot and surrounding trim
Cheers
https://www.sau.com.au/forums/topic/475975-wrecking-r32-gtst/
59 minutes ago, jmknights93 said:
I literally asked him the same question haha.
And you were in before me.... damn it!!! lol
7 hours ago, R32GOJIRA said:
What is the dash cluster surround like? Are all the switch mounting tabs in good condition?
It has a couple of hairline cracks at the top but otherwise in good condition
4 hours ago, Adz2332 said:
how much on the coils? assuming 2 door and 4 door are the same mounting?
I'm keeping the coils on the motor as I want to sell motor complete with coils, loom, ecu etc
Or are you referring to the coilovers?
Edited by AMR33
30 minutes ago, Adz2332 said:
sorry meant the coilovers
pretty sure coupes and sedans are the same. The difference is between gtst and gtr/gts4, but I'm happy to be corrected on this
asking $800 ONO for the coilovers
how old are they? which BC model are they??
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
