Wrecking R32 GTST
 Share
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
    • I installed it all myself,  It was really easy to install.  I got a professional to do the degas/gas.
    • Finally had some time after working on other projects to jump back on this thing. Pulled all 4 wheels to check the brakes over and lucked out, only needed to bleed them/change fluid to get everything working!    Took it for its first quick spin (around 2km) up the road and ran great! Sounds like I have a left rear wheel bearing that needs replacing and there’s a shake in the steering wheel but the tires are absolutely junk on this thing and had been sitting flat when I went to first look at the car so we’ll see if that’s the cause.   Tach randomly started working but I notice if my hicas light comes on the tach stops working 🙃 yay for electrical gremlins
    • Bunnings car park it is! if you buy the kind of dampers with the adjustable top on the strut you can see it, red, purple? So many options.
