1991 R32 GTR. 145000kms on chassis. 32000kms on motor.
Engine built by ERD in QLD. NSW rego till April 2019. Still has QLD mod plates
60k ono - 0406217874
Engine
- R34 Nur Head
- Nismo N1 Block
- Race port & polish
- Tomei Oversized Valves
- Tomei Springs
- Tomei Retainers
- Tomei Valve Guides
- Tomei Bery Rings
- Tomei Lifters
- Tomei 272 camshafts
- Tomei Cam Gears
- Tomei Head Gasket
- ARP Head Studs
- Blueprinted
- R34 Nur Crank (collared & grub screwed)
- R34 Nur Girdle
- Tomei Pistons
- Tomei Oil Restrictors
- Tomei Rings
- Tomei Rods
- Tomei Pins
- ARP Rod Bolts
- ACL Bearings
- Tomei Oil Pump
- Trust Extended Sump & Pickup
- Ross Balancer
- Standard Water Pump
- Koyorad Radiator
- Samco Rad & heater hoses
- Garage Defend carbon cooling panel
- Trust oil filter relocation & PWR cooler
- All new standard sensors
- Custom catch can with braided line
Intake & Exhaust:
- Standard Plenum repainted
- ARC Drag Intercooler
- HKS Hard Intake Pipe Kit
- HKS MAF Delete Pipes
- Trust TypeR BOV
- Standard Manifolds Port Matched
- Garrett GT2860-5
- Midori Dump Pipes
- Midori Front Pipe
- Decat
- HKS Silent HiPower exhaust
Suspension & Drive Line:
- HICAS completely removed, nismo bushes put in place of ball joints
- All bushes in car replaced with Nismo bushes
- Nismo engine, gearbox, steering rack & diff mounts
- All wheel bearings, ball joints, tie rods, rack ends & kingpin bearings replaced with genuine Nissan parts
- Tein HA Super Street coil overs (rears rebuilt 2 years ago)
- GKTech Front roll center correction spacers
- GKTech V3 Front Castor Arms
- GKTech Prototype front camber arms
- GKTech V3 rear camber arms
- GKTech V3 rear traction arms
- GKTech V3 rear toe arms on brackets to subframe
- R34 GT-R Vspec brembo conversion (PMU pads & DBA rotors)
- HEL brake lines
- BM55
- HEL clutch line
- New master cylinder
- Nismo slave cylinder
- NPC Billet twin plate solid center
- Standard gearbox
- 4.375 diff gears from GTS4
- Standard diff centers
- Kansai strut braces front and rear
Electronics:
- Haltech Platinum Pro
- Haltech Racepak
- Haltech 4Bar Map Sensor
- Haltech boost control solenoid
- Haltech Fuel Pressure Sensor
- Haltech Oil Pressure Sensor
- Alpine CDA137EBT Head unit
- Alpine Type R 6" Speakers ×4
- Alpine 5ch Amplifier
- Pioneer 12" Sub in box
- Viper 855XV alarm with central locking
- Battery relocation to boot
Fuel System:
- HKS Fuel Rail
- Bosch 950cc Injectors
- Ballast delete
- Turbosmart FPR1200
- Reused HICAS lines as fuel lines
- Peterson inline filter
- FPG intank system with twin walbro 460
- Speedflow Teflon line and 200 fittings throughout
Exterior:
- Nismo front bumper
- Abflug Carbon front lip
- Nismo bonnet lip
- Nismo 3 piece side skirts
- Nismo rear pods
- Nismo boot lip
- Fujimura rocket dancer lip carbon
- Top secret canards carbon
- Work Meister sp1 3p 18x10+18 wrapped in hankook RS4 semi slicks
Interior:
- Nismo Seat Covers
- Nismo Floor Mats
- Nismo carbon mirror cover
- Nismo shift knob
- Nismo shifter boot
- Nismo handbrake boot
- Nismo 320kph dash (when fitted cluster was adjusted to read the same as the original odometer)
- Nardi deep corn 350mm perforated leather
- GKTech billet handbrake lever
- Eyebolts installed ready for harnesses
- FPG custom boot floor
Made 330awkw @23psi on e85. 390awkw @28psi injectors maxed. Turned down to 330awkw e85. Tuned by Benny at Benchmark solutionsIMG_3344.thumb.jpg.c98ad5bfcb853f4ff58fd752d7994f14.jpgIMG_3516.thumb.jpg.cb6a070d895bb46f46dd31d653a68cad.jpgIMG_3279.thumb.jpg.79f1849b1ce55048c8dcfc8233bf5b28.jpgIMG_3203.thumb.jpg.a763d644a0ad48e2439041471c545230.jpgIMG_3207.thumb.jpg.b0ad030a3e04fbfdaecf35e0fe34ed7a.jpgIMG_3518.thumb.jpg.9c6187bdf472fd78b9ab3a31b37f4d28.jpgIMG_3522.thumb.jpg.bd1728baebd46018591a9f8021630be7.jpgIMG_3517.thumb.jpg.d35fc8c8ff0f04688a08a11174869006.jpgIMG_3237.thumb.jpg.9aabfb3255988045f0f43ae706d49d5f.jpgIMG_3236.thumb.jpg.d52ff77ca1c0c25376f8b7e723b25b0b.jpgIMG_3235.thumb.jpg.87897dc1e92174bdece7b1d8cd00a0ce.jpgIMG_3234.thumb.jpg.390cd63295e1229672fecd1f7ddc245d.jpgIMG_3233.thumb.jpg.20466caee6a7db9cc7110821380e9bd9.jpgIMG_3232.thumb.jpg.316d9e2e42d17f585a0e371d141c0f53.jpgIMG_3206.thumb.jpg.4568e3cc1f30a7faf2313bb45c6cad18.jpgIMG_3098.thumb.jpg.470eebfe0381f842a6a9213900d773a3.jpg
  • Like 1
https://www.sau.com.au/forums/topic/475978-1991-built-r32-gt-r/
There is a phone number listed in the ad that could answer all your questions instantly.
As a general rule, I wouldn't negotiate with somebody who hasn't taken the time to inspect or have the car inspected, or even bothered to call. They tend to be time wasters.
  • Like 7
  • Haha 1
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
    • I've also been eyeing their rear axles for my car. I purchased seat mounts from them about 7 years ago and they were hot garbage so I've been a little wary about purchasing them. With that being said, please buy them and get back to us haha.
    • Can a moderator please move this into the right category.. I've accidently put this into racing build thread 🤦🏽‍♂️
