1991 R32 GTR. 145000kms on chassis. 32000kms on motor.
Engine built by ERD in QLD. NSW rego till April 2019. Still has QLD mod plates
60k ono - 0406217874
Engine
- R34 Nur Head
- Nismo N1 Block
- Race port & polish
- Tomei Oversized Valves
- Tomei Springs
- Tomei Retainers
- Tomei Valve Guides
- Tomei Bery Rings
- Tomei Lifters
- Tomei 272 camshafts
- Tomei Cam Gears
- Tomei Head Gasket
- ARP Head Studs
- Blueprinted
- R34 Nur Crank (collared & grub screwed)
- R34 Nur Girdle
- Tomei Pistons
- Tomei Oil Restrictors
- Tomei Rings
- Tomei Rods
- Tomei Pins
- ARP Rod Bolts
- ACL Bearings
- Tomei Oil Pump
- Trust Extended Sump & Pickup
- Ross Balancer
- Standard Water Pump
- Koyorad Radiator
- Samco Rad & heater hoses
- Garage Defend carbon cooling panel
- Trust oil filter relocation & PWR cooler
- All new standard sensors
- Custom catch can with braided line
Intake & Exhaust:
- Standard Plenum repainted
- ARC Drag Intercooler
- HKS Hard Intake Pipe Kit
- HKS MAF Delete Pipes
- Trust TypeR BOV
- Standard Manifolds Port Matched
- Garrett GT2860-5
- Midori Dump Pipes
- Midori Front Pipe
- Decat
- HKS Silent HiPower exhaust
Suspension & Drive Line:
- HICAS completely removed, nismo bushes put in place of ball joints
- All bushes in car replaced with Nismo bushes
- Nismo engine, gearbox, steering rack & diff mounts
- All wheel bearings, ball joints, tie rods, rack ends & kingpin bearings replaced with genuine Nissan parts
- Tein HA Super Street coil overs (rears rebuilt 2 years ago)
- GKTech Front roll center correction spacers
- GKTech V3 Front Castor Arms
- GKTech Prototype front camber arms
- GKTech V3 rear camber arms
- GKTech V3 rear traction arms
- GKTech V3 rear toe arms on brackets to subframe
- R34 GT-R Vspec brembo conversion (PMU pads & DBA rotors)
- HEL brake lines
- BM55
- HEL clutch line
- New master cylinder
- Nismo slave cylinder
- NPC Billet twin plate solid center
- Standard gearbox
- 4.375 diff gears from GTS4
- Standard diff centers
- Kansai strut braces front and rear
Electronics:
- Haltech Platinum Pro
- Haltech Racepak
- Haltech 4Bar Map Sensor
- Haltech boost control solenoid
- Haltech Fuel Pressure Sensor
- Haltech Oil Pressure Sensor
- Alpine CDA137EBT Head unit
- Alpine Type R 6" Speakers ×4
- Alpine 5ch Amplifier
- Pioneer 12" Sub in box
- Viper 855XV alarm with central locking
- Battery relocation to boot
Fuel System:
- HKS Fuel Rail
- Bosch 950cc Injectors
- Ballast delete
- Turbosmart FPR1200
- Reused HICAS lines as fuel lines
- Peterson inline filter
- FPG intank system with twin walbro 460
- Speedflow Teflon line and 200 fittings throughout
Exterior:
- Nismo front bumper
- Abflug Carbon front lip
- Nismo bonnet lip
- Nismo 3 piece side skirts
- Nismo rear pods
- Nismo boot lip
- Fujimura rocket dancer lip carbon
- Top secret canards carbon
- Work Meister sp1 3p 18x10+18 wrapped in hankook RS4 semi slicks
Interior:
- Nismo Seat Covers
- Nismo Floor Mats
- Nismo carbon mirror cover
- Nismo shift knob
- Nismo shifter boot
- Nismo handbrake boot
- Nismo 320kph dash (when fitted cluster was adjusted to read the same as the original odometer)
- Nardi deep corn 350mm perforated leather
- GKTech billet handbrake lever
- Eyebolts installed ready for harnesses
- FPG custom boot floor
Made 330awkw @23psi on e85. 390awkw @28psi injectors maxed. Turned down to 330awkw e85. Tuned by Benny at Benchmark solutionsIMG_3344.thumb.jpg.c98ad5bfcb853f4ff58fd752d7994f14.jpgIMG_3516.thumb.jpg.cb6a070d895bb46f46dd31d653a68cad.jpgIMG_3279.thumb.jpg.79f1849b1ce55048c8dcfc8233bf5b28.jpgIMG_3203.thumb.jpg.a763d644a0ad48e2439041471c545230.jpgIMG_3207.thumb.jpg.b0ad030a3e04fbfdaecf35e0fe34ed7a.jpgIMG_3518.thumb.jpg.9c6187bdf472fd78b9ab3a31b37f4d28.jpgIMG_3522.thumb.jpg.bd1728baebd46018591a9f8021630be7.jpgIMG_3517.thumb.jpg.d35fc8c8ff0f04688a08a11174869006.jpgIMG_3237.thumb.jpg.9aabfb3255988045f0f43ae706d49d5f.jpgIMG_3236.thumb.jpg.d52ff77ca1c0c25376f8b7e723b25b0b.jpgIMG_3235.thumb.jpg.87897dc1e92174bdece7b1d8cd00a0ce.jpgIMG_3234.thumb.jpg.390cd63295e1229672fecd1f7ddc245d.jpgIMG_3233.thumb.jpg.20466caee6a7db9cc7110821380e9bd9.jpgIMG_3232.thumb.jpg.316d9e2e42d17f585a0e371d141c0f53.jpgIMG_3206.thumb.jpg.4568e3cc1f30a7faf2313bb45c6cad18.jpgIMG_3098.thumb.jpg.470eebfe0381f842a6a9213900d773a3.jpg
  • Like 1
https://www.sau.com.au/forums/topic/475978-1991-built-r32-gt-r/
There is a phone number listed in the ad that could answer all your questions instantly.
As a general rule, I wouldn't negotiate with somebody who hasn't taken the time to inspect or have the car inspected, or even bothered to call. They tend to be time wasters.
  • Like 7
  • Haha 1
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
