Hi guys,
so buying qll bits i need for my upgrade and what is left is a tubonand injectors.
turbo will be a hybrid bolt on build by uk company.
re injector, they cost around £600. Alternative is r35 gtr injectors and reading numerous posts it seems they are a straight fit but some say you need to change an o ring. Can anyone share their experience on this?
is it a straight fit?
i see lots of sets going for £200 sexond hand and also few set of either bosch or denso at £160 for 6 injectors brand new. Is it too cheap to be true / good quality?
https://www.ebay.co.uk/itm/NISSAN-SKYLINE-GTR-R35-INJECTORS-STANDARD-X-6-R34-R32-R33-GTT/153354371979?hash=item23b4a2038b:g:grsAAOSwrfRcTZjQ
https://www.ebay.co.uk/itm/6-Genuine-750cc-Turbo-Fuel-Injector-71lb-Direct-Fit-Nissan-GTR-R35-350Z-G35-M35/183394861581?fits=Model%3AGT-R|Plat_Gen%3AR35&hash=item2ab32f820d:g:67QAAOSwvu5bfBkX
if i fit them in, considering my original ones are 370 cc, would the car run at all for me to drive to dynonplace?
I think answer is no as it will flood the engine with fuel.
So my second question is if i fit it after installing my link ecu  with base image, could i just go there an change the injector size so it will let me drivr it to the garage?
https://www.sau.com.au/forums/topic/475981-rb25det-neo-injector/
You want to buy ~1000cc (or more like 1100cc these days) Bosch EV14 based injectors from a reputable supplier.  Get the right length ones for the Neo, with wiring adaptors.  viz https://www.injectorsonline.com/au/fuel-injectors/nissan/rb25-neo.html
You're looking at ~$100 ozzy each.  Not 100 pounds each.
And no, you cannot fit massive injectors and drive it to the dyno.  Get them fitted there.
And do't buy injectors from random ebay shitters unless you know the ebay seller as another vendor elsewhere - like, I'd buy from injectors online** (see my link) on ebay if there was a special or something.
**or any of several others.
R35 injectors are a waste of time, stop being brain washed by the stupid Americans.
Get some nice 3/4 top feeds, in the right size and be done with it. Make sure the injectors are 3/4 length NOT 1/2 length with extenders to make them 3/4 as they will not work!
Some suppliers say they "fit" but really they don't, I learnt the hard way from reading way too much internets. Enjoy the read here:
thanks, question I have is one of the tuners I spoke to was saying you can't fit a much larger injector than what the car needs. so for instance if you fit a 1000cc to a 400hp, the spray pattern is differnt and can run rich and die in traffic lights by flooding engine.
not sure if that is a correct statement but purely what I was told hence checking. it doesn't sound right to me as you can tune the duty cycle but again not sure if the duty cycle is at 10%, what will happen. would you end up with uneven spray ....
re injectors you suggested, are they a straight fit with a need to do the wiring only ?
so if I read correctly in injector size is 3/4 inch or 1.92 cm for rb25det neo ?
This is true of old school injectors but not the better injectors for sale now.
i looked up the bosch injectors, unless I buy it from AU . it is much more expensive in the UK.
Almost anything you buy here is twice the price. an extreme clutch and flywheel did cost me £1k in gbp which is around 1.7 aud.
can't assume it will be that much in AU. injector dynamic is quite respected and well known here but pricey . has anyone used them ?
how about sard?
^ What he said.
Follow Dose Pipe's advice - 3/4 is not a diameter or a length.  It is 3/4 of full length injectors.  The same basic injector is usually available in 1/2, 3/4 and full length.
Also, I have pointed you at injectorsonline.com for a good reason.  Read the info attached to each injector on offer there for Neos.....
checked them out on injectorsonline but that is AU, by the time I pay postage/ tax and ... it cost the same as what I could buy here hence why I wanted to fit r35 injectors as they are way cheaper
https://www.injectorsonline.com/gb/fuel-injectors/nissan/rb25-neo/1000cc-xspurt-injectors-x-6.html
have you used xsprut ? at £392 doesn't seem to bad
Your tuner is a moron, find a new one.
I run 1550cc injectors and my car doesn't die at the lights nor does it flood the engine.
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
