EFR 8374, IWG 0.92 A/R.  (slight damage to turbine wheel at edge)
6Boost T4 Divided Manifold to suit IWG.  Ceramic Coated.
Turbosmart IWG75
The lot for $2000ono.  (not looking to sell in parts at this point - it is cheap enough as is).
Guys, be aware that the reason for the cheap price is that the 8374 turbine wheel has sustained some damage.  I have provided a close up of the edge of the fins.  As you can see,  a small piece of something must have gone through it and it has taken 1 to 2mm off the outer edge (on all fins).  This was installed on an RB26/30 as per photos below.
I can say hand on heart that we did not 'know' about this damage. The car has been making the same outright power and I did not notice any lag etc.  The only reason we found it at all was that we removed the exhaust housing to get it ceramic coated and then saw it.   Believing this was a problem (and having some contacts at BW) we sourced a new one anyway and I have held onto this unit as a legitimate spare to throw on if we ever had an issue with the replacement turbo.   We never have, so its been in the cupboard for about 2years now.    We are now also going to bigger setup hence not needing this manifold and it made sense to move the lot as a kit.
For someone looking at upgrading from twins to a single and on a budget, this is good way to net you 600rwhp @1.4bar    (as this one did, even with this damage).  And then you're setup for upgrades later if you feel the need.
Parts 'missing' from it:
  1. You will either need to block the blow-off valve if you are using externals - or source a replacement one. (edit: I might have sourced one, so will confirm).
  2. I have kept the speed sensor, so you can either fit your own or block off.
I'm not in a big hurry to move this - its just clean up time.   I could still use it as a spare, so while I'm open to some negotiation please don't super low ball me.  Its very cheap buying as it is..
https://www.sau.com.au/forums/topic/475990-efr8374-more/
  • 2 months later...
Back up FOR SALE!
Unfortunately - sadly - I've been stuffed around by a fairly active member on here who wanted it - We had several emails and phone calls - even gave me his address to send it to.     Then put me off for a while due to some other bills. (which was fine) .
I held it for him as he said he was still keen - but would need a month or so -  what do you know - now he doesn't return emails or PM's.  Nice.
I even went and found a replacement BOV for it for him - so the only 'missing thing' now is a speed sensor.
I wish people would just man up - if your circumstances have changed - just let me know - I'm not going to bite your head off.
Price drop to $1900
  • Sad 1
https://www.sau.com.au/forums/topic/475990-efr8374-more/#findComment-7903932
  • 3 weeks later...
@GTScotT
Yep - recent Dyno attached.  Yes we wondered about EGT at the time as well - but the general consensus was something small had gone through it. Can't be 100% sure -  Was making around 620 at wheels at the time - didn't have EGT sensors, but wasn't on the bleeding edge or anything.
Do have 6xEGTs now though!  And knocking out 684 on a hub dyno.
(Note we are rolling on boost down low deliberately.)
https://www.sau.com.au/forums/topic/475990-efr8374-more/#findComment-7906727
  • 9 months later...
Just now, bri73y said:
Did you end up selling the front diff gears ??
The 4.375?
Nope - still got front and rears (the rear includes a full GT-R diff housing, but no diff).
https://www.sau.com.au/forums/topic/475990-efr8374-more/#findComment-7926186
  • 1 year later...
On 09/03/2020 at 12:21 PM, R32 TT said:
The 4.375?
Might be a long shot but would you happen to still have the rear 4.375 gears you mentioned above?
https://www.sau.com.au/forums/topic/475990-efr8374-more/#findComment-7954203
If you’re chasing diff gears, Neat gearboxes manufactures diff gears for the R200 diff in a heap of ratios.
  • Thanks 1
https://www.sau.com.au/forums/topic/475990-efr8374-more/#findComment-7954205
  • 1 year later...
  • 3 months later...
On 27/04/2019 at 5:38 AM, R32 TT said:
Back up FOR SALE!
Price drop to $1900
Might be a long shot, but do you still have this? I'm interested.
https://www.sau.com.au/forums/topic/475990-efr8374-more/#findComment-7973405
    • Sounds like the solenoid might be cactus, if the solenoid trigger wire was still attached (and it was just the main power to the starter itself remove). Just to provoke Neil haunting me for the rest of my life... Have you tried tapping it with a hammer while someone switches the key to start? This might work for the fuel pump too... 😛
    • I need help dealing with an engineer who is massively overcharging me for an engineering report on my modified, written-off Jeep to get it roadworthy. 🔹 Initially, he quoted me $3,500 - $4,500. 🔹 First invoice: $5,315 (already above the quote). 🔹 Second invoice: $1,375. 🔹 Now, he has sent another invoice for $3,100! This is way more than double what I was originally quoted. I feel like I’m being ripped off. Has anyone dealt with something like this before? What can I do? Any advice on how to report him or fight these unfair charges? Would really appreciate any guidance! 🙏 Am in Adelaide.
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
