So you have just spent how much on a donk from CRD?
You are willing to drop $5K on a bucket of shit snail "to save money because it bolts in?"
In this situation you aren't even "skimping" on the most important part of the car which seems to make it even more ridiculous to throw that HKS snail on!
 Sell your current setup to some other JDM bell end for a hugely inflated price like you are prepared to spend on that prehistoric shit heap......
Realistically it will probably be about $2 or $3K at the most for a new manifold, gate/s and a new dump pipe by the time you sold the old setup.
You will probably save $3K and have a car thats faark loads quicker, more fun to drive & more reliable long term because it wont need 100% throttle & 6500rpm to overtake 75yo Mavis in her Toyota Prius on her way to church on Sunday morning.
  • Haha 3
Yeah ok point taken ? ?you've given me a good laugh reading that after the shit day I've had !
Everyone will probably slap me for this, but my manifold that the current turbo bolts to is a split pulse T4 flange with a T4 to 99mm v band adaptor to mount the hks.
Don't the Precisions and Garrett's have T4 flange mounts ?
Loving this....rip out the engine and rebuild it again for now reason and put it back together with a big BW turbo with a pipe straight out the bonnet.  That be fun.
90's power curve FTW thats all ya need to scare the tits off ya mrs. Who wants to go REAL fast with all these cops around you just want to scare the passenger on a full pull hahaha.
Send IT!
If the only reason you're not getting a non HKS turbo is because you don't want to fab a new dump... Get a non HKS turbo!
  • Like 1
If your keeping up with the conversation you'll see it looks like I'll be changing to a Precision.
Definitely 6466 or 6870. Leaning towards 6870. Would still love to have v band in and out on exhaust housing, V bands are awesome to work on and no gaskets. A/r sizes in v band i think are .082 and .96, but twin scroll is 1.00 and up. What housing sizes are recommended and is twin scroll that much better than using the v band inlet housing ?
i know i'm just jumping on the peer pressure train.
I'd say its worth it but it does depend what you want to do with the car. lot of drag boys dont bother.
V band is nice but how often do you really take your turbo off the manifold?
Just make sure you get a quality gasket and studs etc. and you wont have any dramas
Ok spoke to Con at CRD again this morning. Decision made - PT6466 with T4 twin scroll 1.00a/r will be going on.
Bye bye HKS ? Be sad to see her go but am very excited to see results when completed !
  • Like 2
4 hours ago, Dose Pipe Sutututu said:
Yes!
Good stuff man, glad we all knocked sense into you!
(waits for the Precision hating lot to chime in)
Nah, won't be hate. Just subtle passive aggressiveness from the EFR master race...
  • Like 1
Quite often if you own an oil burning PTE & dont have 16× 22 billion micron inline oil filters?
8 hours ago, Dose Pipe Sutututu said:
Yes!
There are Johnny that 1's for you ?
Edited by Mick_o
  • 2 months later...
    • Solid update, got all the downforces now.  You going to be running aus time attack again? love the jacking solution, spend the dollars on what makes it go fast is best way.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
