Hi guys,
i am going mad over my horn wiring as it does not work. Here is what I have:
5 pin relay:
pin 30 to battery ( fused at 10amp)
ping 87 is power to horn positive . Horn is grounded to the chassis on the other pin so one positive from relay and one from chassis
Pin 86 is connected to horn switch . Horn switch then has a ground to streering wheel column.
pin 85 is ground
this doesnot work when i press the button or even when i connect 86 and ground together.
if however i give positive to 86 from the starter key wiring , it beeps!!
i thought i need ground to 86 but i need positive.
anyone that can help please
https://www.sau.com.au/forums/topic/475992-wiring-horn/
3 minutes ago, GTSBoy said:
car wiring generaly switches to earth.  Your horn button switches to earth.  The other end of the relay coil obviously has to be 12v+.
Not sure i understood. The button is getting power from leg 86 of the relay and groun from chassis.
What do you mean car wiring generally switches to earth?
any suggestion on what i am doing wrong?
https://www.sau.com.au/forums/topic/475992-wiring-horn/#findComment-7897656
The two haves of the relay are completely separate.  The power to run the relay's coil comes form the car's original circuit.  The power that eventually runs the horn (on the switched side) is completely separate.  The drawing for how to hook it up is usually printed on the side of the relay.
https://www.sau.com.au/forums/topic/475992-wiring-horn/#findComment-7897657
12 hours ago, GTSBoy said:
12V+ -> relay coil -> horn switch -> earth.
That's what you have to get right.  The other side (the output of the relay) is easy.
can you please explain it in wire to pin term.
I explained above on how I have connected it and again below:
power from battery to pin 30.
ground - pin 85
power to horn - ping 87
wire to switch / horn button - pin 86 . this is then grounded on horn side
sort of like below
https://www.google.com/search?biw=1920&bih=1009&tbm=isch&sa=1&ei=D4JYXLbQNcHkgwefjJWYAg&q=relay+horn&oq=relay+horn&gs_l=img.3.3.0i67j0l5j0i7i30l3j0i8i30.24132.24132..24379...0.0..0.48.48.1......1....1..gws-wiz-img.BEvgJH0xOJU#imgrc=mccxtHvKA7bRDM:
when I push the horn, 86 and 85 is connected so power should go through from pin 30 to 87 which doesn't happen.
86 is not hoocked up to any other power source so not sure when I press the button, whether 86 gets power from relay to connect to 85 or ..
https://www.sau.com.au/forums/topic/475992-wiring-horn/#findComment-7897740
Every time I do this (every five years or so) I have to figure it out again.
pin 30 power from battery (correct)
pin 85 also requires power (can take from pin 30 or the original power source)
pin 87 goes to horns (correct)
pin 86 goes to horn button
This applies to the usual set up where the horn works by earthing through the horn button i.e. the horn button is not supplying power it is completing the circuit by earthing.
https://www.sau.com.au/forums/topic/475992-wiring-horn/#findComment-7897744
1 hour ago, drifter17a said:
So does 85 need power, it is ground?
86 has no power , simply a wire to button which also has a ground connection
if i touch power/12 to 86. It does beep
Sounds like you are in a bit deep here man. Baby steps, walk before you run etc.
relays aare sosimple. They have how they work on the side of them ......
https://www.sau.com.au/forums/topic/475992-wiring-horn/#findComment-7897762
Just follow my instructions. If you think you know better why ask?
https://www.sau.com.au/forums/topic/475992-wiring-horn/#findComment-7897821
NO!  It does not fu(king matter whether you have the switched side going in or out of either 85 and 86.  They are BOTH just terminals that are connected together inside the relay when you power the coil.
What matters is that you put battery power into one of them, and the connect the horn button (and therefore the EARTH on the other side of the button) to the other switched terminal.  The earth is provided by the horn button being pushed, closing its switch and connecting to earth.  The power flows to that earth through the relay from the other side of the relay's switched terminals.
I have just rephrased what I have posted before, and what Kiwi posted.  Same same.
Not rocket surgery.
https://www.sau.com.au/forums/topic/475992-wiring-horn/#findComment-7897854
Lol, don’t fume:)
Trying to understand this.
would you get a direct battery feed to either leg 85 or 86?
I think the problem as i suspected and you pointed out is neighter 85 or 86 have power to energise the relay and I have been confused by looking at relay wiring instructions.
if I get an accessory light to 86 , 86 it will not draw power from that accesorry to power the horn, it is simply used to energised the relay so i don’t need to fuse it , do it?
power is supplied from pin 30 to pin 87 which goes to horn
https://www.sau.com.au/forums/topic/475992-wiring-horn/#findComment-7897857
Actually, I dun f**ked up.  But only because I don't care which terminal is which number.  I mixed up the switched side and the coil side.  Look at the below image....
Power to run the load (the horn) actually goes in through T30. T87 is the output to the horn.
T85
Now, you could do either of the following (but not both).
1) You could swap the connections I described in the underlined text to be the other way around if you wanted to.  It would still work.  Those terminals just get joined together when the relay's coil is powered.
or
2) You could put the same power supply onto both T30 and T86 (using a wire that connects them both outside the relay AND to the power source of choice).  Then the horn button (and its earth) get connected to T85.
It is usually important to put the activation power onto the right terminal (that would be 12V onto T86) because they often have a diode in them to stop back voltage spikes when the relay is opened (ie, when you turn it off).
https://www.sau.com.au/forums/topic/475992-wiring-horn/#findComment-7897859
Just revisiting my decision, i have directly plugged 85 and 30 to battery meaning horn works regardless of ignition status.
It is not the best to leave it direct to battery so want to rewire 85 to a positive ignition that is switched with ignition, what would you use?
i am thinking to use fuel pump or some fuse that comes on with ignition.
is it a bad idea to do that?
there will be no draw from pin 85 or minimal , right? Should I fuse it to 2 amp or so as it is only energising the relay so power from battery is sent to horn directly
https://www.sau.com.au/forums/topic/475992-wiring-horn/#findComment-7898247
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 🤣 And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 🤪
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
