hi,
I have purchased a greddy boost controller and have a hard time adjusting it.
I understand gain is in percentage on how much boost you want . I started with 5% and now on 30% which gives me 11psi.I don't know what the percent really means. . 30% of base boost or ... they could have just made it easy by sticking to psi.
then gain is set to 15% as I understand gain is used if boost drops at the top rpm, gain will maintain the boost .
start, is what you want the greddy to kick in from. I am not really sure what that means but reading from what people have said, it should be your desired boost -4 psi. so it is set to 7psi.
warning , it is what you want the boost controller to be the limit . i set it to 11 psi
limiter, is again in bloody percentage on how much boost it should release when you  hit 11 psi. i set it to 5% .
now what I see is , on first gear 7 psi as max but it is usually on 5- 6 psi.
second gear it hits the 11 psi and stops at 12psi at max ! but again runnig around 8psi range
third , same as second.
4th same as 1 st gear.
I am really confused and fed up with driving up and down to bloody adjust it .
should your boost decrease / increase depending on gear or is it more rev dependent ?
https://www.sau.com.au/forums/topic/475999-geddy-profec/
It's not a closed loop boost controller, therefore you CANNOT make the setpoint a psi target.  The main setting is basically the duty cycle of the solenoid.  The bigger the number, the more it is bleeding off and the higher the boost will go.  When you get to 100, it cannot bleed any more and whatever boost you have achieved is all you will get.  Of course,the boost may stop rising or the turbo may overspeed and die before you get to 100 anyway.
The gain (set gain) is for trimming the main control result to eliminate droops or spikes.
https://www.sau.com.au/forums/topic/475999-geddy-profec/#findComment-7897853
Thanks for clarification.
i started with set of 0 and gain of 0.
now at set of 30ish , I achieved around 12psi and have set the gain to 15%.
from reading manual I understood the gain to be used to keep the boost if it drops . So for instance if it boosts to 9psi at 4k rpm and back down to 5psi at 5k rpm, you use the gain and keep raising until it consitantly stays on 9psi from 4k onward.
am i reading/ understanding it wrong?
https://www.sau.com.au/forums/topic/475999-geddy-profec/#findComment-7897855
    • 😂 thanks guys. The diagram i had did not have the breather on it at all. Much appreciated.
    • Geez, engineers fees have definitely gone up. Mine back 2007 cost me all of $300. Mind you, I had to go back to him a few times to get him to write the correct things on the report after he'd inspected it. Things like wrong exhaust size, wrong wheel sizes, etc etc.
    • Can we see a scan of the original quote? The problem with engineers (and by this, I mean, all engineers across all engineering industries) is that there are "engineers" and there are "engineers" (you'll have to imagine the two different vocal emphases on those two versions of the same word. Engineering is a mindset - your farm kid who spent his life rebuilding the tractor will likely make a good engineer. The farm kid who spent his life taking photos of butterflies.. perhaps not. But on top of that mindset, the modern engineer has to learn how to write so that there is absolutely no way of being misunderstood. Proposals/budget estimates/quotations are one place where this is absolutely vital. You have to delineate your scope of supply with extremely hard boundaries, and anywhere where there is any possibility of not being able to have such a hard boundary, you need to write language that will cover you from scope creep, cost overruns, the inevitable interference of the client or their "engineer", etc etc. Now, if your clients are the BHPs and the Rio Tintos of the world, and similar, then you get good at this. If you are an automotive engineer, pitching work to the great unwashed masses, your skills in this area might not be well developed, because you're only dealing with knuckle draggers trying to get a big block legal in a Torana. And when I say "might not"....I'd suggest there's a better than even chance that any such skills might be completely absent. So, we might be able to look at your quote and see what the opportunities are for rebuttal.
    • It’s an rb25 so a gtst and I’ll get that valve
