Hi all
So i'm planning on putting a fair bit more power behind my 34. Is a factory Neo, 25det manual. However am struggling to find a good clutch option to hold 300kw (expecting somewhere between 500-600nm of torque). The issue i'm having is because the car is a pull type clutch, not push. I'm also struggling to find an actual in depth guide of converting the 34 gearbox to push type, which would instantly solve my issues.
So basically i'm stuck looking for a clutch that can hold that power for pull type, because I cannot find many options over here in New Zealand. That, or has anyone had any experience or know of a guide that shows how to convert it to a push-type system? I'm not wanting to swap my gearbox for an R33 one, as mine is in perfect condition. Have heard something about potentially swapping the bellhousings over though?
Any advice or light on the subject would be appreciated!
https://www.sau.com.au/forums/topic/476002-r34-gtt-clutch-suggesstions/
Don't bother, just run the pull type clutch.
Ring NPC clutches here in Queensland and ask for a Carbotic 6 puck to suit R34 GT-T and you are done.
Have had one for 7 years and love it to death.
What the guy above said. That's what I'm running in my r34 GTT, awesome clutch, never going back to plain exedy unless it's modified... Had a exedy cushion button clutch behind 220kw and the thing failed after 2000kms.
2 hours ago, Dyzzii said:
Is there a way I can contact them without phoning? As i'm unfortunately in New Zealand. If so I may flick them an email and see if they can arrange shipping one over! Appreciate the advice guys!
Doesn't new Zealand have phones? Or is the massive time difference the issue?
  • Like 1
When talking overseas it's not pleasant for either party to have a solid 3-4 second delay before anything said is received by the other person. Makes the entire process a pain. I managed to find their website and email them, but appreciate the remark nonetheless
Um....it's not 1975 any more.  There is no perceptible delay on international calls, regardless of whether you use a landline, a mobile, skype on your computer or a payphone.  Hell, I routinely dial into 20 way phone conferences based in places like Minnesota from my home phone, mobile or computer, from motels and airports on wi-fi and all other sorts of crap, and there's not enough delay to cause any angst.
Also +1 for buy Nismo twinplate, job done, forever. Will obviously bolt up to the standard R34 configuration :p.
You can buy a clutch rated for 309kw when you have 300kw, or you can get one rated for 450+kw when you have 300kw. The Nismo twinplate is easier to drive than everything else listed here.
It is also more expensive. ?
You can buy a single plate clutch to hold 320KW at any brake and clutch shop. I got an Exedy heavy duty clutch and its fine. Or if you want a Nismo twin plate they are available in all the main centres or buy direct from Japan
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
