Hi all
So i'm planning on putting a fair bit more power behind my 34. Is a factory Neo, 25det manual. However am struggling to find a good clutch option to hold 300kw (expecting somewhere between 500-600nm of torque). The issue i'm having is because the car is a pull type clutch, not push. I'm also struggling to find an actual in depth guide of converting the 34 gearbox to push type, which would instantly solve my issues.
So basically i'm stuck looking for a clutch that can hold that power for pull type, because I cannot find many options over here in New Zealand. That, or has anyone had any experience or know of a guide that shows how to convert it to a push-type system? I'm not wanting to swap my gearbox for an R33 one, as mine is in perfect condition. Have heard something about potentially swapping the bellhousings over though?
Any advice or light on the subject would be appreciated!
https://www.sau.com.au/forums/topic/476002-r34-gtt-clutch-suggesstions/
Don't bother, just run the pull type clutch.
Ring NPC clutches here in Queensland and ask for a Carbotic 6 puck to suit R34 GT-T and you are done.
Have had one for 7 years and love it to death.
What the guy above said. That's what I'm running in my r34 GTT, awesome clutch, never going back to plain exedy unless it's modified... Had a exedy cushion button clutch behind 220kw and the thing failed after 2000kms.
2 hours ago, Dyzzii said:
Is there a way I can contact them without phoning? As i'm unfortunately in New Zealand. If so I may flick them an email and see if they can arrange shipping one over! Appreciate the advice guys!
Doesn't new Zealand have phones? Or is the massive time difference the issue?
  • Like 1
When talking overseas it's not pleasant for either party to have a solid 3-4 second delay before anything said is received by the other person. Makes the entire process a pain. I managed to find their website and email them, but appreciate the remark nonetheless
Um....it's not 1975 any more.  There is no perceptible delay on international calls, regardless of whether you use a landline, a mobile, skype on your computer or a payphone.  Hell, I routinely dial into 20 way phone conferences based in places like Minnesota from my home phone, mobile or computer, from motels and airports on wi-fi and all other sorts of crap, and there's not enough delay to cause any angst.
Also +1 for buy Nismo twinplate, job done, forever. Will obviously bolt up to the standard R34 configuration :p.
You can buy a clutch rated for 309kw when you have 300kw, or you can get one rated for 450+kw when you have 300kw. The Nismo twinplate is easier to drive than everything else listed here.
It is also more expensive. ?
You can buy a single plate clutch to hold 320KW at any brake and clutch shop. I got an Exedy heavy duty clutch and its fine. Or if you want a Nismo twin plate they are available in all the main centres or buy direct from Japan
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
