Hi all
So i'm planning on putting a fair bit more power behind my 34. Is a factory Neo, 25det manual. However am struggling to find a good clutch option to hold 300kw (expecting somewhere between 500-600nm of torque). The issue i'm having is because the car is a pull type clutch, not push. I'm also struggling to find an actual in depth guide of converting the 34 gearbox to push type, which would instantly solve my issues.
So basically i'm stuck looking for a clutch that can hold that power for pull type, because I cannot find many options over here in New Zealand. That, or has anyone had any experience or know of a guide that shows how to convert it to a push-type system? I'm not wanting to swap my gearbox for an R33 one, as mine is in perfect condition. Have heard something about potentially swapping the bellhousings over though?
Any advice or light on the subject would be appreciated!
https://www.sau.com.au/forums/topic/476002-r34-gtt-clutch-suggesstions/
Don't bother, just run the pull type clutch.
Ring NPC clutches here in Queensland and ask for a Carbotic 6 puck to suit R34 GT-T and you are done.
Have had one for 7 years and love it to death.
What the guy above said. That's what I'm running in my r34 GTT, awesome clutch, never going back to plain exedy unless it's modified... Had a exedy cushion button clutch behind 220kw and the thing failed after 2000kms.
2 hours ago, Dyzzii said:
Is there a way I can contact them without phoning? As i'm unfortunately in New Zealand. If so I may flick them an email and see if they can arrange shipping one over! Appreciate the advice guys!
Doesn't new Zealand have phones? Or is the massive time difference the issue?
  • Like 1
When talking overseas it's not pleasant for either party to have a solid 3-4 second delay before anything said is received by the other person. Makes the entire process a pain. I managed to find their website and email them, but appreciate the remark nonetheless
Um....it's not 1975 any more.  There is no perceptible delay on international calls, regardless of whether you use a landline, a mobile, skype on your computer or a payphone.  Hell, I routinely dial into 20 way phone conferences based in places like Minnesota from my home phone, mobile or computer, from motels and airports on wi-fi and all other sorts of crap, and there's not enough delay to cause any angst.
Also +1 for buy Nismo twinplate, job done, forever. Will obviously bolt up to the standard R34 configuration :p.
You can buy a clutch rated for 309kw when you have 300kw, or you can get one rated for 450+kw when you have 300kw. The Nismo twinplate is easier to drive than everything else listed here.
It is also more expensive. ?
You can buy a single plate clutch to hold 320KW at any brake and clutch shop. I got an Exedy heavy duty clutch and its fine. Or if you want a Nismo twin plate they are available in all the main centres or buy direct from Japan
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
