*Wrecking*
R34 skyline midnight blue
*(parts only)* *more parts not listed*
Prices negotiable!
Seats 300 lot front and rear
Seat belts 30 each
Boot lining 80
Bonnet 550
Boot lid 220
Motor ecu & box 1200 sold
Front strut brace 110
Tail lights 400 or 220 each
Headlights 550 sold pending payment
Front bumper 350 sold pending payment
Rear bumper (silver) 120
Front gaurds 200 set fl60(dent) fr140
A.c. fan 25 sold pending payment
Throttle cable 20 sold
Radiator 70 sold
Radiator shroud 30 sold
Locks and keys 100 sold pending payment
Door outer handles 20 each
Door interior trims 30 each
Window switches 15 each
Driver door electrics control 40
Door inner handles 15 each
Center console 60
Cluster (@220k) 100
Dash 200
Glove box 35
Kick panels 10 each
Sunvisors 40 set
Steering wheel with airbag 100
Steering clock assembly 70
Msg for more parts and prices I will respond asap.
No emails please. Scammers reported!
Zaq - 04382three511six
[email protected]
https://www.sau.com.au/forums/topic/476008-wrecking-r34-na-sedan/
  • 3 weeks later...
Staggered and dished 18" speedy inferno rims / mags .
1 has a small buckle on the inside which has never caused me any issues and always balanced up in the 5 years ive used them. Makes any car look and feel instantly better. Good tread.
Front 225 40 18 Tread 80%
Rear 235 40 18 Tread 65%
Would love a polish up.
$650.
Currently on the red ford.images%20(4).jpeg20190215_183518.jpeg20171210_175405.jpeg
  • 1 month later...
  • 1 month later...
Bump!
Cant edit the previous post, need bits just ask.
Speedy Infernos have sold
Still have bits to sell.. make me an offer:
R34..:
Seats
Doors/handles/trims/windows
Mirrors
Glove box
Boot lining
Brakes
Tail lights
Cluster 220k
Strut brace
Seat belts
Interior
dash
ect ect.....
Lots sold
Lots left
Just right.
Clearance prices if i have what you need plus postage!
Also have:
Sr20 coil packs x6 $10 neg each + postage
3.5" hi flow flanged cat $20 + postage
Old r32 front and rear seats front with old covers on the and missing some rail bits , tear in drivers bottom right side and bit of glue on the rear midle upright. Make an offer pick up only.
Rb Wolf 3d v4 plug in with pc usb to serial cable... askin $250 make an offer was gonna use it on my 20 det but decided to stick with stock and piggy back so i dont need it.
20171210_174650.jpeg20171210_175507.jpegIMG_1525384594459.jpeg20190116_131408.jpeg20190202_201402.jpeg20190116_131425.jpeg20181113_205208.jpeg20190226_180723.jpeg20190207_195432.jpeg
  • 1 month later...
  • 1 year later...
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
