all,
I know this may have been asked before but couldn't get a direct response to what i needed
I have ran the cable to boot and ready to relocate. i want to mount the battery on the top shelf by removing the hicas ecu.
unfortunately there is no bolt or whatso ever to hold the batter in place. I am thinking of drilling a whole on the top shelf but my question is, is the top shelf very close to fuel pump / plastic pump and I could put a whole in the tank?
https://www.sau.com.au/forums/topic/476020-r34-relocate-battery/
Yes it's very close to the fuel tank, getting a bolt or 4 in there (properly) will be a bit of a headache too. Pull off the fuel pump lid and have a look under there to get an idea of what you're working with - I'll give you a hint, it's not very much at all.
In terms of drilling into the tank, yes it's a pretty real risk so be careful, or re-consider your need to mount it in that exact location.
yeah very small much tiny space, did place it on right hand side
i am running positive through a kill switch which is the one below
https://www.ebay.co.uk/itm/Car-Truck-Van-Battery-Isolator-Cut-Off-Kill-Switch-SPST-MAX-50V-200A-On-Off-Out/123429881445?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
how would you cover the bottom when wires are in to ensure it won't touch body etc?
i am thinking a battery box but rather not buy one as have a battery bracket but this needs to be inside something
R33's had the battery in the boot and the battery holder bolts straight into the r34 the holes are already there. I had to modify the bracket for the ecu behind the battery though to make it fit. Here is a pic but it is not finished.
  • Like 1
