all,
I know this may have been asked before but couldn't get a direct response to what i needed
I have ran the cable to boot and ready to relocate. i want to mount the battery on the top shelf by removing the hicas ecu.
unfortunately there is no bolt or whatso ever to hold the batter in place. I am thinking of drilling a whole on the top shelf but my question is, is the top shelf very close to fuel pump / plastic pump and I could put a whole in the tank?
https://www.sau.com.au/forums/topic/476020-r34-relocate-battery/
Yes it's very close to the fuel tank, getting a bolt or 4 in there (properly) will be a bit of a headache too. Pull off the fuel pump lid and have a look under there to get an idea of what you're working with - I'll give you a hint, it's not very much at all.
In terms of drilling into the tank, yes it's a pretty real risk so be careful, or re-consider your need to mount it in that exact location.
yeah very small much tiny space, did place it on right hand side
i am running positive through a kill switch which is the one below
https://www.ebay.co.uk/itm/Car-Truck-Van-Battery-Isolator-Cut-Off-Kill-Switch-SPST-MAX-50V-200A-On-Off-Out/123429881445?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
how would you cover the bottom when wires are in to ensure it won't touch body etc?
i am thinking a battery box but rather not buy one as have a battery bracket but this needs to be inside something
R33's had the battery in the boot and the battery holder bolts straight into the r34 the holes are already there. I had to modify the bracket for the ecu behind the battery though to make it fit. Here is a pic but it is not finished.
  • Like 1
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
    • Just report the OP (via the 3 dots menu at the top right of post) and request deletion.
    • And boosters can be rebuilt by the same sort of brake shops that will rebuild a brake booster.
