all,
I know this may have been asked before but couldn't get a direct response to what i needed
I have ran the cable to boot and ready to relocate. i want to mount the battery on the top shelf by removing the hicas ecu.
unfortunately there is no bolt or whatso ever to hold the batter in place. I am thinking of drilling a whole on the top shelf but my question is, is the top shelf very close to fuel pump / plastic pump and I could put a whole in the tank?
https://www.sau.com.au/forums/topic/476020-r34-relocate-battery/
Yes it's very close to the fuel tank, getting a bolt or 4 in there (properly) will be a bit of a headache too. Pull off the fuel pump lid and have a look under there to get an idea of what you're working with - I'll give you a hint, it's not very much at all.
In terms of drilling into the tank, yes it's a pretty real risk so be careful, or re-consider your need to mount it in that exact location.
yeah very small much tiny space, did place it on right hand side
i am running positive through a kill switch which is the one below
https://www.ebay.co.uk/itm/Car-Truck-Van-Battery-Isolator-Cut-Off-Kill-Switch-SPST-MAX-50V-200A-On-Off-Out/123429881445?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
how would you cover the bottom when wires are in to ensure it won't touch body etc?
i am thinking a battery box but rather not buy one as have a battery bracket but this needs to be inside something
R33's had the battery in the boot and the battery holder bolts straight into the r34 the holes are already there. I had to modify the bracket for the ecu behind the battery though to make it fit. Here is a pic but it is not finished.
  • Like 1
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
