On 10/1/2020 at 11:02 PM, Unzipped Composites said:
I'm sort of committed to single scroll now. I thought long and hard about twin scroll, but decided against it in the end when I bought the manifold. If I was going to do twin scroll, I wanted twin gates rather than the divided plumbing from the manifold, but decided the extra heat, packaging and point of failure were issues for me.
You make a good point with the diff ratio though. At the moment the diff is stock, and I know it's going to be wayyy too short for the power I'm aiming for around Barbagallo, I'll be on limiter in 4th or having to go to 5th for half of the straights, which is where you lose seconds. So I know I need to go taller, and hadnt really thought about that with picking a turbo.
I rejected split pulse/twin gate for generally similar reasons.  Mainly because everything gets so busy and so hot. A properly thought out and executed divided pipe to a 60mm gate is what I'd consider if split pulse was chosen as "the next step".  Truth (for me) is that there's too many other areas requiring priority consideration if you want to make the combination faster.  The next step (for me) is to make the driver faster... :)
Generally, the GTX3576 makes a lot of sense for tractability and a wide useable torque range regardless of whether single or split
  • Like 1
  • 1 year later...
Okay thread necro!
Back it again with the GTX3576R Gen 2. New motor, with same-ish parts bar the Kelford 264/272, ATi Balancer, Nitto Oil Pump, Plazmaman Intake and Plazmaman Cooler.
IATs are nice and low now and very consistent run after run. The previous HDi core would heatsoak quite fast where as the Plazmaman core didn't. Post run it recorded a max of 29 degrees C, where as the old HDi core would shoot up to 40.
Pretty good having Alex build the motor, giving me warranty on it although I'm tuning it. He did ask for a few additional trims to be added and for timing to be taken out in the midrange however he knows I will track this car and the motor is running H beams not I Beams.
Managed 437.9kW at 1.7bar dropping down to 1.5bar. I suspect with the gate vented to atmosphere and no cat the motor should naturally make a but more power. It's a bit shy of my unrealistic goal of high 400s but let's me honest that was a number I threw in the air a few years back.
  • Like 4
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
