On 2/21/2019 at 12:04 PM, Titan X said:
Any suggestion on new injectors? Looking at the Bosch 1000cc injectors. I don’t want to worry down the line about replacing again if I do extensive HP hainsgains
Nice car - and welcome to SAU!
Looks like the steering wheel is still on the "wrong" side for you guys - are you allowed to drive them like that where you live?
I don't think you would ever need 1000cc injectors on an RB20, unless you fit a big laggy turbo and run on E85 fuel?
The new injectors these days can manage a wide HP range much better (ie a big injector can manage fuel OK for low HP) - but what sort of HP gains are you chasing in your RB20?
Checkout the RB20 turbo upgrade thread for info on getting results from the RB20
https://www.sau.com.au/forums/topic/103095-rb20-turbo-upgrade-all-dyno-results/
I have an R33, so I've never looked at the thread.
I'll likely get flamed by the R32 GTST crowd for this comment, but many owners in Australia with an RB20 in the engine bay look to other engines if they're seeking big HP gains (eg RB25, RB26, RB30, 1JZ, 2JZ, Barra etc).
I'm sure with the right mods you can get your RB20 singing, with ample power for a street car - I just don't think 1000cc injectors is the best 1st step.
cheers
Mike
  • Like 1
Your car looks mint.
Don't do to much unless you plan on getting another one that nice.
once you start modding it's hard to stop ahaha.
1000cc way to big.
Fuel pump and it's wiring and lines first then injectors. 400 hp is about topping a 20det so you only need the injectors to be as big as gtr stickies 444cc.
Front mount intercooler. (Return flow to avoid chassis holes)
High flow rb25 turbo
Zorst setup
Pod filter.
Bleed valve
Aftermarket ecu
That should be enough for fun
Start with a bleed valve and don't boost over 12 psi or you will break the zorst wheel
