It looks clean and mean, Even better up close. Top notch Julian.
With the gear box done it'd be the complete package I'm thinking.
Cheers
PS. That'd be 500-520 rwkws ? :P
Edited by Sinista32
Picture taken just after resprayed and was just sitting there for the photo. Thanks for noticing thirty two.
It made 535.8 sinista but haven't leant on it yet.
niiice power :P too bad your front bar looks like its fallin goff :S hot lookin though mate !
Edited by widebody32
  • 4 weeks later...
Can you do us all a big favour, put that front bar on and take some more photo's, it would be on my computer wallpaper. That is one fat powerful skyline. And I'm not even all that crazy about 32's.
finally got one! got it from autostyle in sydney on sunday and just took some pics of it. not too clean cuz the rain won't seem to let up, but the car's in awesome knick! just a few slightly worn rubbers around windows, lights etc. interior's pretty much on par with the outside. not immaculate but quite awesome nonetheless. couldn't be bothered getting the keys to open it and snap pics sorry! but yeah, car's totally standard 'cept for the 33 wheels, cat back exhaust and turbo timer. very happy with it. gave it a thrashing yesterday but that'll be it pretty much cuz i'd like this car to keep working for a while but it's got plenty o' poke. cheers guys!
Damn, I didn't know there were that many nice cars in Canberra.
having only moved back to Canberra 4 months ago after being away for 6 years I noticed how canberra's car scene has improved (still too many lancer with evo kits for my taste though)
better put up pics of my cars just in case people spot me and willing to give a wave.
Here is the R32 GTR I got back in mar 2005.
Not modified too much (Power FC next on the list)
Dec 1989 R32 GTR
Apexi AVC-D ( 1bar)
Apexi Multi-checker
Twin HKS pod filter
Twin HKS Super Blow Off Valve
3.5 inch cat back exhaust (unknown)
Blistein shocks (way too hard for Sydney)
Cusco rear strut
Juran front strut
ARC low GT wing (currently off due to defect)
Atessa controller
White Volks TE37 17x9+15
Ventus R-S2 245/45R17 (makes the odo alittle out 200mtrs/5kms)
Pivot Turbo timer
Momo Spider steering wheel (CF look)
8 ball type gear knob (CF look)
Nismo 320km/h speedo
HKS Boost gauge
Cheap water temp, oil pressure, boost(psi) gauge (soon to be replaced by some Defi ones as soon as I get off my ass and move the air cond unit somewhere else)
Cheap Earthing kit (don't think it does anything at all)
Good black wired alarm/immobilzer (obvious not mentioning brand)
Changed to GTS-T headlights
And this is my FTO, it's my rice car and hoping to get rid of it soon so I can spend more money on the GTR.
Anyway just bored at the moment and thought I'd post here. Hope to see you guys on the road.
Michael
Holy riced FTO yaf.......I spent way too much on my FTO =(
What have ya done to the FTO?
Yer, the FTO has been riced up before selling it. My cousin is a mechanic at midas and is helping me fix it up and sell it.
as for mods, it's practically stock except for rice stuff like gear knob, petals, seat covers, mags and stereo.
I sometimes get blinded looking at it.
Mivec, what have you done to your FTO?
I sold my FTO a little while ago but it had:
Extractors
Intake
Slotted rotors
Converted it to a manual.
I've still got a carbon fibre centre console part you can have if you want it.
And now I know that it is you I see at Midas all the time!! You came up and said hi to me the other night when I was filling up!! Haven't been to badminton in ages though so I haven't seen you there.
*swoon* =P
    • At least you're now aware of the problem and can come up with a solution.
    • Dang. Keen for further updates when you get to it.
    • Welcome to SAU Thomas, sounds like you'd had a bit of a an unlucky start with the car, hopefully you get some better luck now!
    • 1. No need, it only gets used once then is locked in place by the nut 2. EN-62 point 6 shows the conical washer the other way around (BTW I know we discussed above, I hope you are changing the idler as well, while it is no guarantee the bearing is a actually bad, it looks terrible) 3. I'm not really clear on the question, are you worried because it was easy, not hard, to remove the custom timing trigger? As long as it doesn't spin on the crank (when the bolt is tight) all good 4. Yeah just make sure the brand is easy to read as it rolls past 5. The part number is on the listing under the description, 13023-42L00. Given there is a custom part on there for timing (presumably outside the cover), they may have decided to leave that off; I think I would put the washer in there as it also helps seal the timing case from crap getting in.
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
