Oooh who is doing it?
There's a guy on Canberra Cruises that has a pretty awesome blue Soarer. I have a bit of a soft spot for them.
That would be Aaron,
Getting David Hand to do it...who knows how it will come out, but my insurer guarentees the work, so if it comes out bad, it will be going back until its perfect.
As zeb said. you need big turbo for 260rwkw
Nistune for like $200 (i can do the soldering)
Tune for about $150-$200
$350ish and you'll be at 210ish rwkw
Your on. We'll do this sh!t.
Who do you trust locall to tune my daily ?
Ambitious on an op6 then huh ?
If it has GT30 internals it MIGHT get there.
Max realisticly would be 200rwkw.
Then again with all the happy dynos in Canberra you might infact end up with a dyno sheet that says 450rwkws lol
lol... prolly...folk here are just awesome hey!
I get CRD to do mine for the 32. But solid beleiver that it's how it feels to me on the road that i measure against. When it has more than I'm comfortable with then thats nuff for me.
Edited by Sinista32
Ed at autotech has tuned mine 3 times, never had an issue with anything (There is a few bad stories going round about him, but they're all on big hp numbers).
He's familiar with the nistune software and has done a good number of nistunes.
If all is well with the car it should only take an hour on the dyno.
With the stock turbo it came out at 215rwkw at 11psi. on a dyno that i know for a fact reads lower than ESP's
Thats still very high for a stock OP6 lol..
My highflow 21U made 200rwkws at 13psi on the hills motorsport dyno...and was backed up by the big black dyno
Gotta love canberra dyno's
should through my Soarer on one and see what it comes out as.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
