Danny im sure i've seen your car at the anu before and pee'd on it. Its a pretty good spot for photos at night.
Are you a student there?
Yeah I went there for a couple shots of my car recently, but nah I'm actually still in college lol.
^^^fixed.^^^
Tis a fine looking piece of machinery. :thumbsup:
Hahaha ! thanks for that :P
  • 5 weeks later...
  • 1 month later...
Hey Guys,
Im not very active on SAU, but thought I'd post my HR31 Coupe, hoping to get back amongst it, since the R31 scene is pretty well dead (well 3 people in the ACT, everyone has pretty well moved on).
I've recently finished a major cleanup of the outside of the car, as well as a conversion from the standard redtop RB20 to a Silvertop, loom & ECU. All the work has been done by myself and my mates, and I'm really proud of it.
Some pics at the Skyline Nationals in Goulburn:
with the 180:
I have some future plans for it, mostly continuing to restore it to as good condition as possible inside and out, and also some new bearings and rings for the motor, with a GTS-R Manifold, T04E, R33 side mount intercooler, external 38mm gate, and exhaust. Not really aiming for a power figure, but expecting around the 200 at the wheels on 10-15 psi.
I also have a black 180SX which I like to do skid pan days, track days and drifting events in, a VL Calais Turbo which I'm fixing up, and another R31 which I drive to work.
Hope to see some people on the weekend at the Snowy 1000 :)
hey guys
new to sau been on here for about a week now
have never been happier with a car the stagea is everything you need and want rolled into one :D im always keen to help anyone out mechanically or with planning a.c.t events so dont be afraid to ask
hey guys
The stagea is a great car. My mate Verms has an autech one. Great space and great power! the 26dett in those things are nuts.
  • 3 weeks later...
Hi All,
My name is Brad. Long time reader, first time poster here.
Been frequenting the SAU forums for the past few months, until I finally registered as a member when I decided that I would take the plunge and get a Skyline of my own!
It took me about 2 months or so of searching, enquiring and inspecting many different R34s from all around ACT and NSW before I eventually came to own my "almost perfect" R34 GT-T.
I have had it for a couple of weeks now but haven't got around to posting on here till now...
2001 Model - Series 2
Pearl White
85,000 kms - not sure if genuine, but great condition leads me to believe it may be.
Manual
Factory Sunroof!
Basically 100% stock standard except for HKS Turbo timer and rear adjustable control arms and bushings (which I had installed).
Came with 20" rims on it and a spare set of 100% brand new stock rims which I have put on as I was not a fan of the 20s.
http://i1288.photobu...4/BradD54/8.jpg
http://i1288.photobu...4/BradD54/7.jpg
http://i1288.photobu...4/BradD54/3.jpg
http://i1288.photobu...4/BradD54/5.jpg
http://i1288.photobu...4/BradD54/6.jpg
http://i1288.photobu...4/BradD54/4.jpg
http://i1288.photobu...4/BradD54/2.jpg
http://i1288.photobu...4/BradD54/1.jpg
Note the number plates which I am stoked about! Just got lucky when I had to transfer rego.
Current plans for it are:
Remove stock solenoid and install manual boost control+boost gauge - as I think it might be overboosting...
Turbo back exhaust - Stock one is a little too quiet/restrictive.
Decent panel filter for intake
Black/dark grey 18" TE37 style rims - can't justify the cost for legit Rays TE37!
Then ECU + Tune once I've got it to a stage I'm pretty happy with.
Will be doing little details here and there, but basically just full "stage 1" mods and then I'll see from there. Just have to get back on top of money now after spending so much just to get it! ;)
The R34 GTR has always been a dream car of mine, and since I cannot afford to shell out for the "real thing" I settled for the next best!
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
