Hi everyone,
Got my R34 GTR Vspec (black) a few weeks ago now which was personally imported.
Completely stock for now apart from a nismo superpro cat back and nismo engine oil cooler.
Sorry about the poor photos but will get some better ones up in due course.
Spotted a white R34 Vspec II in civic over the weekend (v. clean).
Just wondering if there are any other R34 GTR's here in ACT?
Cheers
  • Like 1
:woot::action-smiley-069::wub::3some:
so goooooooooooooooooooooooooood. What future does this beast behold?
I think we have R34 Vspec II NUR Mjade (never seen) not apart of SAU.
White R34 GTR Vspec II Posted once, never heard of again.
R34 GTR silver with black bonnet, wingless - spotted but not on SAU
BB R34 GTR vpsec? I see casually parked near me - not on SAU.
To answer your questions - ACT has R34 GTR's but they don't appear on SAU.
Edited by RosieR34
Thanks guys
For the moment will be kept pretty stock (big property purchase coming up plus it was hard enough to get the fun police to loosen the purse strings and get the r in the 1st place).
Is being used as my daily so not too crazy and keeping it streetable.
Upcoming mods in the future (not necessarily in any order)
- nismo side skirts and rear pods
- set of rims (currently looking at a set of black gtc's)
- tints
- double din dash conversion (ie remove factory sat nav, tape player and relocate climate control panel) btw if anyone has some more info on this or has seen a "how to" that would be great.
- nismo smoked front and side indicators
- ecu and tune
- intake
- dash 5's or 7's
- carbon wing blade (stock blade has faded and chipped paint)
- nismo twin plate coppermix clutch
- replace mfd screen (polarising film has cracked and deteriorated over time)
- finish off exhaust from turbo to cat
This should keep me pretty well done for the next little while.
Would be keen for a act sau meet with you all even though it's a bit chilly.
Cheers
Thanks guys
- tints
- ecu and tune
- intake
- dash 5's or 7's
Cheers
Put -9's in if you want to keep response but increase the powahh. ;)
  • Like 1
That's awesome man ! Sounds like a bit of restoration project then power gains - which is awesome nonetheless. Nismo kit looks amazballs and prefer it more than the ztune kit (deep pockets for them). I've always thought the R34 GTR needed to be slammed to compliment a nismo/ztune kit - but of course, like most things, it's an opinion.
Can you explain the double din dash conversion a bit more? What will you be getting instead of the Sat Nav, tape player? Just removing, I'm guessing the sat nav feed goes through the MFD?
Very keen to look over the GTR, have never been able to actually look inside one in person.
As for meets, we have a meet every Friday night (whether it's hot or cold - the location normally changes). The hot meets are normally at Grevilla park (City) which we all stand around and have a chat while looking at people's toys and the cold meets are normally undercover to break the wind-chills. I believe Eji picks where the meets are which best suit the conditions, I have not been for awhile so unaware where the current meets are being held.
btw the mJade gtr is an SAU member Rosie.
For real? Never knew that, must have been a member long time before me and stopped posting. I believe his missus owns Skafies R32 GTR? Be good to see him at a meet or cruise one day LOL the mjade Nur is my pinnacle dream :D
Quick post
My new daily Tokyo Taxi. Transferred and Rego'd into my name
100% OEM except head unit.
Sailed through Dickson pits on first go, took less than 10 minutes
As an aside my 34 GTT (245rwkws) will be up for sale in the next month or so.
(joey jumped in the way, minor damage,so getting new bonnet and latch)
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
