f**k it, ill post the daily. For those that know me, and my nismo addiction, KNOW THIS. I have combated it by buying another Nissan with which to buy more Nismo.
The Nismo Cube or for the ladies the Jismo Cube, i know i know, it's extremely sexy.
The list of Nismo parts keeps growing. The latest addition was the MAD Nismo wheels. they are hectic as. Loving the Nismo handle protectors as well.
Image may contain: car and outdoor
  • Like 1
All i'm going to say is CONGRATS! Congrats on getting the other half to sign off on a Cube! If only mine could see the light:laugh:
I think they look cool and...its a freaking Cube- packing one would be like playing a game of Tetris!
Fun to drive around town?
  • Like 1
Fun isn't the word i'd use lol Practical? Maybe...
For a car it's slow and doesn't corner overly well, and this is the rowdy 1.5L version. However my god it is easy to drive. Visibility is fantastic and it has the best cornering circle of any car ive ever been in, it can do a u turn in 1 and a half car spaces. It's also pretty comfortable all things considered.
My other half loves it, she loves how easy it is to drive. She just said it took a while to get over the looks of it.
  • 11 months later...
Well here is mine.
R33 GTST 1997 with sunroof
Gt3582r
48mm turbosmart gate w/ screamer
Custom mani
3.5inch dump and all the way through w/xforce muffler
monsta FMIC
Freedy plenum
Bosch 1000cc injectors
460lph walbro
Turbosmart fuel reg
E85 making 360RWKW @18 psi
Vaastoen wheels
GTR wing
S2 front bar with nismo lip
Oh and fully forged rb25 with all the goodies.
New r35 coils on the way and then we push more boost and more power[emoji16]received_2042995045727821.jpegIMG_20180616_133956_564.jpgIMG_20180629_142836_452.jpgreceived_1872274982824440.jpeg
  • Like 2
  • 4 months later...
  • 9 months later...
  • 3 months later...
  • 1 year later...
  • 4 weeks later...
I'm 5 years late on the cube convo... My 6 year old wants a Cube, I'm like yeah no 🙅🏼‍♀️
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
