pics as promised!
dont care bout rego
people are paranoid.
Dude, making me jealous, wish I had the time and money to get that sort of stuff done on mine before it was sold. :( It's looking so clean there even without the kit. Good stuff!
cheers man, im a bit concerned about my kit and my driveway :S meh, ill raise the car if i have to i spose.
its taken me 12 months to get it from stock to this. so another year and its going to be done (with maybe an engine swap :()
  • 3 months later...
i hope i don't get shot for this. bearing in mind i am buying an r32 gtr come year's end, i do at the moment need a mode of transport and that currently is an ef falcon. got a venom kit, pacemaker headers, sitting on koni's and king springs and thats about it. nothing special but its still my baby. currently has the driver's door bashed in a bit :)
I guess it's about time I post up here.
Aus delivered '91 R32 GTR
Rebuilt engine
Ross Racing pistons
Rebuilt turbos to N1 spec
N1 oil pump
N1 water pump
Baffle sump
Splitfire coils
3" exhaust from turbo's back
Apexi power-fc
K&N pods
Tein suspension
AP racing front discs
17" simmons fr-17
Custom FMIC + radiator + oil cooler
Probably more but I can't remember.
Hopefully I can catch up with some of you guys when the warmer weather returns.
Cheers,
Brad
Edited by OZR32GTR
  • 5 weeks later...
is that sort of a dark aqua colour? if so i spotted you a couple of days ago, cant remember where but... :(
Depends on the light you see it in.
You can see it green, blue (mostly), bluey-green.
as the missus would say, its absolutely gorgeuous :bunny:
Thommo had pics that showed it as more of a green colour, its really mostly blue tho.
I float about most of canberra, as i'm a roaming tech with sites in Belconnen, Civic, the Airport, Woden and I live around Tuggernong as well. Best way to pic it is the plates, i haven't swapped them over to ACT yet.
Edited by nsanity
  • 1 month later...
Hi guys,
here are some pics of my car and new setup
1989 R32 GTR Veilside Evo 3 kit in Bayside blue with different pearl and metallic
Ganador electric mirrors
17x10 and 17x12.5 Panasport rims with 275 40 17 mickey thompson street drag and 315 30 17 advans
POWER
727.5 RWHP on light tune with pump fuel, expect on more boost and proper tune to see 800 or so
ENGINE and GEARBOX
2.7lt 88mm bore
Line honed, torque plate bored, deburred, decked standard late model block
Standard crank modified for dry sump setup (F**cked a good one)
Jun rods
Jun pistons
ARP head and main studs
ACL race bearings and Head gasket
280 deg cams
Ferrea 1mm oversize valves
Performance springs vave springs, retainers and collets
Head porting by myself along with polished chamber.
Tomei adj cam gears
Ross Harmonic balancer
Gates Timing belt
ECU and ELECTRONICS
Autronic SM4 computer
Autronic R500 CDI
Rice Racing Water injection kit with custom Tank controlled by Autronic
Intercooler water spray controlled by Autronic
Splitfire coils
Relocated battery to boot
Custom 140 amp alternator
OILING SYSTEM
Nismo catch can
Trust oil cooler and remote oil filter
4 stage peterson dry sump oil pump with custom oil tank and Drive and low oil pressure shutoff
Petrson Oil filter
Castrol TSW Motorsport oil
FUEL SYSTEM
1000cc injectors
tomei fuel rail with twin feed
HKS fuel reg
twin motorsport fuel pumps and custom surge tank
100 octane shell v power fuel
COOLING
Davies craig electric water pump
Davies craig twin 13" electric fans
Koyo alloy Radiator
Custom deflector plate
Silicon Radiator Hoses
EXHAUST
custom F1 merge port exhaust man
62mm xtr racegate
Custom Mr turbo turbo Specs witheld
4" dump pipe
with HKS 3.5 system
DRIVELINE
Exedy triple plate carbon clutch
Nismo slave cylinder
Braided clutch line
Upgraded standard box
C's Short shifter
Custom one piece tailshaft
KAAZ two way rear diff
Redline oils throughout
INTAKE
Twin drift filters and custom intake
5" intercooler with 4" inlet and outlet
4" intercooler piping
All braided lines and silicon hose
Polished standard manifold with modified inlet to 4" and number six runner enlarged
INTERIOR
Recaro front seats
Nismo Race harness
Veilside 340 km speedo
Blitz boost controller
Auto gauge oil press,volts oil temp and boost gauge
Auto gauge 5" tacho with shift light and oil temp,water temp,boost,and fuel temp gauges
Gizzmo shift light
Razo gear knob
Blaupunkt DVD player and speakers and amp with in dash screen
SUSPENSION
HKS drag coil overs all round
Tanabe Adjustable castor rods
Cusco camber arms
Hicas lock bar with all lines and pump removed and modified single stage power steer pump
Field torque split controll
BRAKES
Porsche brembo front calipers
Alcon 324mm discs front
R33 brembo rear callipers
R33 rear brembo discs
All braided lines
Motul 600 brake fluid
All Modifications were done by me including all braided lines and fabrication.
Thanks Unigroup engineering and rice racing for tuning so far.
If you require any work similar i do this work as my hobby and have started a business JAY'S RACE ENGINES.
You can contact me on 0422214621 Julian
Edited by widebody32
Hi guys,
here are some pics of my car and setup along with a list of the mods.
Should have it going again in about a month as had an oil pump let go
POWER
718.6 RWHP on light tune due to injectors and map sensors maxed and as you can see by the spike in the graph wheel spin was very evident. I know the afrs are way out but as i said this was just a tune to drive it around and get some kms on it. Will keep you updated when i sort all this out but expect on more boost and proper tune to see 800 or so
ENGINE and GEARBOX
2.7lt 88mm bore
Jun rods
Jun pistons
ARP head and mains
Was Jun oil pump but due to a breakage am fitting dry sump arrangement 4 stage peterson
Jun 266 deg cams coletts and retainers
Ported head
Tomei adj cam gears
1000cc injectors
tomei fuel rail
HKS fuel reg
twin motorsport pumps and surge tank
Polished standard manifold soon to be replaced with trust item
splitfire coils
electric water pump
ross harmonic balancer
62mm xtr racegate
4" dump pipe
with HKS 3.5 system
Apexi power fc d jetro with 3 bar map sensors and hand controller
Os giken triple plate
Standard gearbox soon to be replaced with pfizner
Short shifter
Twin K&N filters and custom intake
5" intercooler
Koyo Alloy Radiator
Twin thermofans
Nismo catch can
Gates Timing belt and hoses
INTERIOR
Recaro front seats
Nismo Race harness
Trust oil temp, press, boost and water temp, omori centre oil temp, fuel press and oil press
Autometer Memory recall tacho
Gizzmo shift light
Razo gear knob
SUSPENSION
Adjustable camber and castor rods
Aftermarket Discs and endless pads all round
niiice power :laugh: too bad your front bar looks like its fallin goff :S hot lookin though mate !
