hey all just getting my skyline on the road should be very soon
1993 r33 gtst
needs some panel work
just the normal mods
intercooler
3.5'' cat back
lower springs
19'' wheels
queen street custom paint
GTR front bar and wing
front bar in pic not fully on
  • 5 weeks later...
hmm, im under construction.
R33 '95 GTST mspec
- xforce 3" turbo back
- greddy fmic
- power fc
- apexi pfc boost cont. kit
- k&n pod
- 19" shadow chrome rims
- HICAS lockbar
- strut braces
- z32 afm
Got a 400R kit, but its not on, atm its just got a GTR front and no skirts (special thanks to previous owner for the incomplete bodykit, awesome)
Got about $3k set aside for body, and will up the clutch/suspension/brakes/injectors/fuel pump/turbo upgraded in due time, probably in that order.
buy a 10k car, spend 10k on it.
hazah for bankrupt!
Edited by Sonuku
Well i have posted my ride in here before but the pic was sh*t. I now have a few better pics and few thing have been done.
you might have seen me cruzing around, as i also ways go for little drives all around the place.
Here are some pics:
  • 4 weeks later...
My new toy
R32 GTS-t M-spec
18 inch rims
intercooler
grey velour interior
full 3" zorst
short shift kit
momo steering wheel
tein coiovers
front bar trimmed to suit intercooler
slotted rotors
4 pot calipers (cuz it's an m-spec)
bleed valve (taken off at the moment for rego)
clearish indicators
at the moment she needs a bit of work...running pretty rich and there is a weird problem that autotech is going to look at on tuesday.
plus need new tyres
reverse switch is broken. going to be replaced this week.
had to get the cannon re aligned a bit because was rubbing on the fuel tank protecter and burnt a hole...lucky.
hopefully it doesn't cost me too much money but hey ive wanted once since i was like 14 so ill probly pour all my money into it :) haha if u see me...give me a wave :P
woooooo
MY BEAST.
MODS= bits here and there.
ive seen you a few times in woden. you may or may not have seen ZCR (silver32) and i (white chaser) a few times in woden aswell.
nice looking car, the eye lids definatly make it look pretty unique
  • 3 weeks later...
1993 Nissan Skyline R33 GTS-T
Heres the list of mods my car has:
Full GTR Body-kit including spoiler
18" starcorp racing rims.
3" Turbo Back Exhaust.
Apexi Blow Off Valve.
Front Mount Intercooler.
Heavy duty clutch.
Forged and polished pistons.
Turbo rebuilt by turbologics.
Engine block crank & head work.
flywheel machining.
PLENTY more planned!!
changing rims soon hopefully and the 18"s will be u for about $500 if anyones interested
I just bought a skyline last friday just gone ... only just signed up to this forum aswell ...
So here she is ... I have allways wanted a skyline ... was tossing up getting a R31 a few years back and gave up on that plan ... now a sweet R32 came up at a price I couldn't refuse so I bought it ...
Here she is ...
1992 HR32 GTS
RB20DE
Automatic .... (In future will be swapped out for a complete engine gearbox upgrade) but for the time being the auto is smooth as hell ...
Has a few mods done to it allready ...
Lowered suspention which is still as all hell
17" SSR wheels
2.5" catback exhaust with canon
Aftermarket rear swaybar
Front bushes have been replaced with nolathane bushes
Custom stereo install ...
Remote central locking , Alarm , immobiliser , remote start
Have some nice red/black Autotechnica racing seats to go into it in future there not the monza style ones ... there the new 08 model seats ...
here is a sideshot of it ...
Finally got some pics uploaded of my new skyline.
1992 R32 GTST type M. - 155rwkw - stock boost.
Black
Manual
130,000kms
ARC side mount Intercooler (good for 200rwkw +)
K&N Panel filter
Iridium platnum spark plugs
R33 turbo (std boost 10psi) std turbo also supplied.
HKS split dump pipe
HKS front pipe
Catco cat converter high flow
Trust PE11 power extreme cat back exhaust
Cam gears fitted and tuned for mid-range
Computer re-map by Dr-Drift
Oil cooler and filter relocater kit with modifyed inner wheel arch to allow more air flow
GTR Front brake upgrade
DBA 4000 Wiper slot rotors all round (near new)
New and upgraded suspension bush's fitted (Caster/front camber/pineapples)
Bilsteins shocks fitted front and rear almost new (Height adjustable)
Whiteline adjustable sway bars front and rear
Hi cas lock bar
Strut braces front and rear
Walbro fuel pump up-grade
GTR front seats (std ones thrown in)
turbo timer
3 point car alarm
Tinted windows
CD player with remote
Edited by livo
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
