hey guys
im still new to the forum but no stranger to imports finally got myself a skyline after a few years of breaking other imports
r32 sedan
r34 NEO RB25DET
full 2-way diff
matching rb25 gear box
new driveline
white line sway bars
extra lock bars
hicas lock bar
full 3inch exhaust
gtr intercooler
huge alloy radiator
cam gears
hsd coilovers
rear strut bar
boot striped
rolled gaurds
aero mirrors
smoked incdicators
17x9+15 zenkai's
aiming for 300kw
and one day when i wake up rich it will be a full track drift car and ill move onto a r34 gtr ;D anyone can dream haha
nice 4 door, good to see another one here in canberra, That makes three locally that i know of. Have one myself, although its looking a bit worse for wear.
Hey everybody!
I used to be on here years ago forgot my details :/
so anyway im back and this is my new drift car as i have a baby on the way so im gunna have a budget drift car!
R32 Skyline
Rb20det
5 speed
button clutch
pedders shocks and springs
full 3 1/2 exhaust
vivagarage widebody r34 conversion
fmic
hks ssqv
not much else lol
Budget!
ill be selling the entire immaculate interior out of it.
cheers guys!
http://i1164.photobucket.com/albums/q569/skyriner32/422519_3105911059217_1607495764_2615982_1445812191_n.jpg
  • 1 month later...
yeah was mine at ESP biggrin.gif thanks drew haha, and cheers man i think ive only seen one other one around town so far was a white one with black rims from memory
Jazz, you got to love a good four door, and yours is a real beauty.
  • 3 weeks later...
should probs post info bout my car..
2000 model JZX100 (s2)
8xxxxx km
Auto :(
Vertex Half-aero kit
Cat-back exhaust, pod + boost tee
Work CR Kiwami in matte black
Cusco coils (10F 8R)
Piccy (sorry, best pic i've got...);
Edited by Scar
Hi guys thought id add my GT-R in here:
1990 R32 GT-R 104,000 logged Km's, with original tool kit.
She is pretty much stock:
Splitfire Coils
Cat-back exhaust
Pod filters
Power FC boost Controller
Twin-plate Clutch
Phat 275/35 tyres.
Custom Paint (gunmetal grey with metalic blue through it)
At the moment its pulling 230awkw and in need for a serious tune..... (im aiming for around 300kw when i get more cash)
Still a work in progress....... she is up on blocks atm im replacing the starter motor....
here is a pic
Edited by Anfanee
Mmmm... I'd like to see that paint in better light to see the blue in it come through a bit more... Having a gunmetal 32 gtr as well they are kind of common, interesting to see it mixed up a bit. I'll keep an ey out for it for sure :)
  • 2 months later...
Hi all my name is Danny, I am new here on this forum so I thought I'd make a little post here about my R32.
1989 Nissan Skyline R32 GTS-T
Has 102,xxx ks on the clock.
List of mods;
. GTR Bonnet, Front guards, Grill, Boot/spoiler, Skirts & Front bar with lip.
. Greddy FMIC.
. HKS dump pipe
. Full turbo back Greddy exhaust.
. HKS pod filter.
. BOSCH 040 fuel pump.
. Adjustable front and rear struts
. Cusco adjustable coilovers all round.
. KKR430 turbo. ( LAAAAGGG )
. HKS cast exhaust manifold.
. R32 GTR injectors.
. Nismo timing belt kit.
. Nistune ECU.
. Blitz dual SBC Spec R boost controller.
. Blitz FATT turbo timer.
. Rays Nismo LMGT3 17 x 9.5 +25 all round.
. R33 GTR seats.
. Nardi steering wheel.
. Blitz boost gauge on pillar.
Pics of the car can be found on; http://imageshack.us/g/59/m5z4.jpg/
Edited by iDannyz
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
