How long did he have it before you brought it. I don't know mat but I could swere Lachlan had it at one stage
Well, I was told Matt had it for 18 months and prior to that his uncle, no idea on his name, owned the car, but no idea how long his uncle owned it for..
ive been telling people that spend max 250thou on a Nismo GTR and youll be raping the 700000 cars out there. Not sure how true it is but the are almost as quick as a formula one at reaching 100km/hr
And you wouldn't be wrong. The GTR rolling off the factory is only at like 40% max power (my opinion/Guesstimate) - The GTR's were built to be modified - Nissan themselves said this on a Doco I was watching. These cars stock are very close to the Lambo Aventador which sells for $1,000,000 AUD.
Nsimo Williams who has been in works with Nismo to produce the R35 GTR N1 also admitted that there is more room for power. Also the 918 is a 800k car - it may be quick. But I don't think Nissan/Nismo tried to contend with the 918 Porsche. I think that is where the R36 will be heading - "be better then the 918, no acceptations" I think is going to be passed to the R36 creators.
Crazy cars - gives me cold chills thinking about the it.
Holy mother of rajab
That's what is "Said" not proven as per such. I wouldn't doubt it, however it actually hasn't been tested, so who knows ! However, 2.1 is gobsmack and the R36 will achieve 1.9sec. 1second car anyone?
Is the r36 even confirmed?
It is. It is confirmed to be released at the 2016 Tokyo Motor show - to which I am kinda wanting to plan to go and see.
R36 is a hybrid - The torque is electric given it more torque then petrol
Edited by RosieR34
  • 4 weeks later...
  • 3 months later...
Not the best pictures atm but don't have other ones on my phone, will probably come back and post other ones later
I have black manual r34 Gt-t with factory sunroof
Engine:
RB25det neo
3 1/2" exhaust
Turbo timer
BOV
The car made 158kw at the rear wheel on 6psi, am happy with that for now
Suspension:
BC/BR coilovers
Cosmetic:
Full z-tune side skirts
Gtr front bumper and bonnet
19x10 Varrstoen 3.3.2 black wheels
Modification plan has not been set into motion yet, but soon...
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
