So car in storage for about two months, battery flat. Charged it up and used another jump start battery to boost. No start. Not even a hint of firing. RACQ guy says he can't detect any spark anywhere. Fuel seems ok, pump runs and you can smell fuel in the exhaust after much cranking. Ran perfectly before. The only thing I can think of that is common to all cylinders, which may have been affected by the flat battery, is the immobiliser. I don't know what brand it is or whether it would allow cranking without spark, but I think it's worth a try. Would I be right in assuming that if I removed all the stuff attached to the positive battery terminal I would effectively isolate the immobiliser? Are there any tricks to this? The immobiliser operates through the lock/unlock button on the remote. Any ideas appreciated.
Tardo
https://www.sau.com.au/forums/topic/476082-gtr-r32-no-start/
Are you semi competent with wiring/using a multimeter? If either of those is no then just take it to an auto elec. Working with poorly installed immobilizers (and they are all always poorly installed) only ends in swearing and wishing you had paid someone to do it.
So, fuel seems good. Replaced the plugs, tested the ignition module, all good, but still no spark. What is the next item upstream of the ignition module? I am running a haltech pro plugin ecu. Is there anything between that and the ignition module that could stop the spark? I am assuming the immobiliser is not the problem because the engine is cranking.
Does any one know of a competent mobile auto sparky in the Brisbane area? Anything to save a tow!
Tardo
Just gets worse! Haltech checked out ok.Thinks, must be Mongoose alarm/immobiliser. Contact them, very helpfull. Steps provided to isolate the system. No joy, still no spark/fire!
So, battery, ok, could make 30ks on the starter motor! Alarm/immobiliser bypassed, ECU checked ok, TCM tested ok, Spitfire coils etc ok. Still no spark impulse at input side of TCM. WTF!!!
C'mon guys and girls, put on your thinking caps please! This is getting a bit surreal!
I was having loads of issues when I had a haltech installed intermittent spark issues like crazy sent haltech out checked out fine. Replaced pretty much everything possible minus one thing I wouldnt have thought of the engine harness. I replaced that and now my car is like brand new. My harness was just so old and brittle that my haltech wasnt getting the proper power causing all my issues. So food for thought check ur volts at ur haltech.
I've had three auto elecs look at this. Sadly, it doesn't involve changing a battery! Two others looked at the TCM as though it was from an alien spacecraft. The car isn't a daily so we will continue to plod along till we get to the bottom of this.
Oh come on!  It is dead simple to troubleshoot this stuff if you are physically present with the car.
  1. Is the ignition signal present at the output terminal on the ECU?
    1. (And as a sub point.....do you know the difference between ECU outputs that output 12V and ECU outputs that supply an earth?  And as a further subpoint, do the auto-eleccies that have looked at it know the difference?)
    2. (And, as a further subpoint, is the Haltech configurable to be either or both on the ignition outputs and is it set to be the wrong sort?)
  2. Is the main power feed present at the igniter?
  3. If you manually provide a trigger into the input side of the igniter, can you get an output signal on the igniter, and then, by extension, at the coil?
If all those things check out....then you start to panic.
This is pretty much it.
I would also make sure that your grounds are properly set up, if you used stock harness and PnP adapter for the ECU you should not have problems but any noise on the coil trigger will cause spark to go off continuously which will manifest as a no-start condition.
You should also verify power to all components like ECU, ignitor, etc are sufficient during cranking. Some ECUs are exceptionally finicky about power supply and will lose ignition sync, etc when when cranking pulls the battery voltage too low.
  • 4 weeks later...
OK guys, just to close this thread, problem fixed. Special thanks to joshuaho96 for your input. I cannot understand the lack of knowledge of our  "auto electricians". Had to go back to basics myself to discover that the TCM had an earth leakage, where three "tradesmen" had assured me that it was functioning as it should. The beast is now purring again. Again, thanks to all who offered advice.
Tardo
PS. Special day today with the delivery of our R34 Mspec Nur. I am very happy to be the custodian of this magnificent vehicle!!!!!
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
