Just installed my mates system for him, sub 6x9's and head unit. Didnt notice it before I put the amp and sub in but when we took it for a "fully sik test cruise" every 10 seconds or so the sound cuts out for a split second, the song keeps going but just for the split second there is nothing, no idea what could be causing it ... I would give you specs of the system but all I know is he has my old JBL GTO400 600watt amp and a 12 inch Pioneer sub. dont remember the model of the deck or anything, so anyone shed some light on this for me
cheers
Sam
https://www.sau.com.au/forums/topic/47611-sound-cutting-out/
12 inch pioneer amp??? lol
Whats the rating for the sub?? maybe your amp is playing up on ya... might be cutting out coz of hign voltage or bad signal...
The problem is most likely the amp im guessing. Are all the speakers cutting out or just the sub??
If it is all then the amp is your culprit. I suggest temporarily fitting another amp to test and see...
https://www.sau.com.au/forums/topic/47611-sound-cutting-out/#findComment-972031
I just had to give back my 1200 w S amp :) so im also looking for another one.. so I have no bass in the car.. and the amp my mate is iusing he bought off me about a week before I had to get rid of my good one, so I wasnt to happy about that one :D
but oh well...
looks liek i need to go shopping :)
https://www.sau.com.au/forums/topic/47611-sound-cutting-out/#findComment-972051
If all the speakers are hooked up to the amp try to plug some directly into the HU.
If all speakers/woofers cut out-
Check all the wires to each speaker/driver. If they short it will cut-out from the HU.
If it's just speakers connected to the amp that cut out-
Make sure your groundwire isn't jumping around and it's in securely attached. Also make sure it's the same guage as your power cable.
Make sure your 'remote" (usually blue) is connected properly and getting current. If it's falling out or jumping around your amp might be being told the HU is off.
Also - if your HU lights cut out (ie. the power to your HU cuts out as well) then you may not have enough current to your HU in which case it's the incorrect power cable you're hooked into or ground wire is lose.
Other than that if all your speakers are hooked up to the amp and you can't be bothered hooking up some speakers to the HU I would put the amp in the car where you can keep an eye on the light and see if it's cutting out.
Hope that helps. Let us know how it goes.
https://www.sau.com.au/forums/topic/47611-sound-cutting-out/#findComment-972218
Well if only the sub is hooked up to the amp and yet all other speakers (I'm assuming they'd be then hooked up to the HU) are cutting out then theres no reason to think it's the sub thats busted.
If all the speakers cut out, but the sub stays on (even though the driver cuts out) AND the head unit stays on I'd find that quite strange.
I would say it's quite strange if the HU stays on but doesn't produce any output. I wonder if it's possible the current is dropping enough for the HU to be unable to produce output but not enough for it to turn off. I've never seen that happen and don't know if it's possible. When your mate gets back see if it happens above a certain volume. This might give you a clue to this fact.
Good luck - let us know how it goes slash when he gets back.
https://www.sau.com.au/forums/topic/47611-sound-cutting-out/#findComment-972683
