Something bad happened.. stalled engine.. won't even turn over.. full charged.. bang noise try start
Hey all
R34 GTT...
Drove to Vic market this morning..
Driving home.. on deceleration toward traffic lights.. going neutral and engine stalls..
Try turn over click click.. click click..
Interesting..
 I have seen very flat battery and bad alternators stall cars...
Anyways brother comes to try and charge me.. try turn over.. still click click..
Smack starter a little and get it to turn over..
Serious metal on metal... Noise..
No oil loss, checked for wet oil in top end by fingering my engine... It has lube for sure..
I dunno.. maybe a rod and snapped or the timing belt...
Can anyone try help me to diagnose the noise? I cannot tell yet without opening anything
My car also died in the city today, Flinders st. Tried to jump it, nothing. Fuel pump was priming, so I thought may be the AFM, unplugged it and it started. Limped it home and starting tearing it apart, tried a working AFM - nothing, front bumper off and checked all intercooler pipes - nothing, fuel rail hose off and turned car into on position - plenty of fuel comes out, pulled plugs - fouled and wet.
Not sure what else, will change plugs tomorrow and hope for the best. Will also check all grounding points.
Can I assume that it’s getting fuel since plugs were wet to rule out injectors and pump?
Anything else I should try?
1 minute ago, ifixedit said:
CAS drive
Curious what ya mean
CAS is driven off the front end of the exhaust camshaft.  Can break.  When it does break, shit stops happening.  Or shit starts happening, depending on your point of view.  Bad noises, for example.
Nice.. gonna borrow friends engine hoist and stand and take a good look..
Might take off front cover first.. look at the timing belt..
Question... Is it possible to remove engine from engine bay without the a.c. compressor??
Don't wanna f**k with the AC.. it works so well
Want to give me a hand as well Hahahaha
Hope you find out the problem.
Yep just unbolt it as well as the power steer pump and put a strap around them to hold to the side out of the way
Edited by NEO25T
Spelling
Thanks NEO
Sadly I actually partially owned a garage in Thailand modding RBs and actually watch a fair bit.. never did a rebuild but will just have a play.. cannot make it worse than it is haha
Maybe I can haha..
I might get the complex stuff like headwork if needed to someone
So anyone is West Melbourne good at working heads
And if need honing done any good places reasonable price?
13 hours ago, ifixedit said:
Thanks NEO
Maybe I can haha..
Any luck today man?
Okay things don't look so sweet.. on first impressions..
Looks like the stalled engine on approach to traffic lights was basically the CAS saying wooooooo something's up!
Looks like the idler pulley for cambelt loose and the bad noise might have been that moving around inside..
Bad bad bad the fact camshafts are not in sync..
Bad bad bad that I tried to keep turning the engine over via starter..
Can anyone weigh in with respect to a starter motor having enough power to bend valves?
I remember even on the half turn the engine was not firing to have a combustion cycle.. so interesting to see if the starter motor would just slightly gouge the pistons..
Time will tell when I go deeper..
Images here in Imgur gallery
https://imgur.com/a/yNRWr3V
Last thing..... Question...
Photo where the balancer pulley is.. since the engine is freely rotating half  to 3 quarters of a cycle... Is the 10mm screw being held by a ratchet bar a typical way to keep the engine crank still while ratcheting off the bolt?
I have ensured there is at least another 30-45 degrees of rotation left from where it's being held..
Or am I suppose to use a longer 10mm bolt and screw it in all the way and let it catch on the engine??
I forgot how the boys use to do this..
I kind of remember using my method haha
Unfortunately that engine is toast by the pics provided. yes the starter is geared low enough to be able to bend valves pretty easily.
How far out of phase are the cams? Can you post a front on picture please.
Continuing to try and start it has definitely done more harm than good.
  based on the little dot on cam gear and marker..
The intake and exhaust would be no more then few teeth out of allignment.. 3-5 teeth out maybe.. and that might be since I released the belt.. and seen it slip.
The main concern in the crank position in relation to the cams.. considering the idler pulley that's no longer mounted would have allowed the crank and cams to misalignment..
I'm going to hazard a guess best chances are... The loose timing belt pulley was jamming the whole thing from turning.. I forced it by forcing the starter motor and heard a terrible grind and stopped instantly.
The grind might have been the pulley.
I'll slowly take her apart..
As far as im able to tell.....Those timing cam gears are completely misaligned if you have that at tdc cyl. The dots on the teeth of the gears should align to the whitelines on the back cover as they indicate where the markers are approximately.
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
    • Yup but for me its the HR ! Cut my teeth on the old holden 6s in the day ! And here's me thinking in the day it was also the 300ZX and the Mitsubishi GT3000 ! All, as well had good lines, but always seemed to need finishing off, style wise.
    • A 180SX has a much better look than a FD. The roofline is far superior being a fastback. It's popups look better. In a world where we all subconsciously add a little bit of low, and wheels of our preference, it's just more handsome than the FD is. The FD just looks 'bubbly' in comparison. It can come down to preference, sure. But "The FD is the BEST looking (on appearances alone) 90's JDM car without question?" Nah. Plenty of questions lol. I could think of 8 cars I think look fundamentally better, and probably a handful of ones that look about on par with a FD. (like say a SW20 MR2) I feel people like/overrate the FD because of it's mythicality/rarity, its rotary and it's unpredictable nature. It probably drives great, you can stuff a ton of tyre under there, has a unique sound, light as hell. I feel that people reading this thinking "YOU CANT RATE A 180 ABOVE A FD BECAUSE A 180 IS A CHEAP DRIFT BUCKET" prove the point about bias as to what the car represents, moreso than how it actually looks.. I feel the 80's boxy/squared off look is becoming better looking due to time, and 90's melted soap bar aesthetics have not aged well. (yet?) And this thread is purely about looks :p
