Something bad happened.. stalled engine.. won't even turn over.. full charged.. bang noise try start
  On 25/02/2019 at 1:10 PM, Slap said:
As far as im able to tell.....Those timing cam gears are completely misaligned if you have that at tdc cyl. The dots on the teeth of the gears should align to the whitelines on the back cover as they indicate where the markers are approximately.
Expand
Yes. The dots should align with cam gears when the crank position at TDC.
I was making the point the cams are in alignment with themselves maybe 1-2 teeth out..
But still most importantly the crank is out of alignment in relation to the cams.
I will stick a camera probe into the sparkplug holes and inspect today..
Hope to have head off by weekend.. slow goings...
  • Like 1
Did you try turning over the motor with a socket before you pulled the belt. Just in case.
If you were on decel the belt most likely slipped the inlet cam making it retarded.
If the belt slipped but after 2 years hmmm.
At first sounded a bit like a corrupted battery. But usually they won't even click till jumpstart then click.
Was there anything unusual with the car just before it happened?
Don't turn any of the cams or crank until you have an idea on it.
Need to get it to tdc gently as possible both crank and cams... slowly turn bit by bit one then the next and so on to keep them from banging the valves.
Good luck.
Ok sorry I've read too many posts lately.
I see you did.
Usually to crack the bolt on the crank you use a big bar and lay it hard against the chassis near the air filter so it's locked in place when on the crank then a real quick clik the starter to crack the bolt.
That won't work in this predicament.
Slowly turn each one bit by bit starting at the inlet then zorst then crank. Gentle slow lil by lil. Cyl by cyl
I got the bolt off combo of impact ratchet and a long pipe on a ratchet.
I use a 10mm bolt in the crank pulley and wedged with a breaker bar.
The bolt was on there good and tight! Took a fair bit of force bit of CRC and patience she finally gave way.
I will eventually get the crank pulley off and attempt to get engine and cams into position for rebelting and see if it will turn over..
Use a probe camera to try and inspect the piston tops for gouging.
I'll report here hopefully later this week..
Expand
Mental note: Don't use a ratchet.  The ratchet can only handle so much torque before you'll shred the teeth off of it.  This is why breaker bars exist.
Good luck with it.
A puller is about 50-60 bucks.
Use those two tens on long bolts to plate, plate with center thread hole , tighten a bolt in it upto the crank bolt location using a cap on the bolt end to suite [taper or flat] so not to wreck the crank bolt hole or damage the crank.
Don't use a gook type puller as it can damage the pulleys.
  On 26/02/2019 at 2:59 AM, Slap said:
Good luck with it.
Expand
Thanks for comments slap.
Hey the bolt can be threaded into the crank a few turns?
It's got the guide in the centre of the bolt?
It's funny how you see people using those triangle g hook type on YouTube..
Hey all.
Dunno if I mentioned that I put a camera down the pistons haha all stuffed inside valves stuck pistons. One piston has a hole in it..
Anyways I spend an hour trying to seperate the engine and gearbox..
Got the engine crane attached. Brought a beautiful chain for lifting too ;)
With some gentle and some not so gentle shaking of the two..
Seems it came apart maybe 8-10mm only. Seem to be having trouble getting them fully apart
It's a manual gearbox for the rb25det neo.
I've removed all bolts.. seems something inside (clutch area) is holding it from coming out.
Is there something I've forgotten or do I keep trying to seperate the two.
Edited by ifixedit
Gearbox input shaft is probably fairly firmly in the clutch.  If there are no bolts still holding the gearbox to the engine, no earth straps, starter motor, etc, then it can only be the input shaft.  You may need/want to release the gearbox crossmember and support the box on a trolley jack so you can change the angle of it to help it disengage.
Yes it is absolutely a pull type clutch and needs releasing before the gearbox will come off, i hope you weren't too rough with it as they aren't very strong and wouldn't be surprised if the clutch is now toast too.
You should consider changing your forum name ?
It's all good.
I jigged a little but nothing too crazy.. upon releasing the pin they finally split.
Clutch and flywheel are fine. Took then off and gave a clean :)
the gearbox would have had a little bit of jiggling but I am sure it's fine :)
thanks for not believing in me! Haha
  • Like 1
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
