Was changing plugs and bit of plastic sucker which was from the spark plug loom fell into the hole
can’t get it out using vacume or gum so question is, would i just start the car and hope it burns or it can do damage?
i am scared it may get stuck between valve and valve seat or i could removr plug, diconnect fuel pump and crank the engine to force it out
https://www.sau.com.au/forums/topic/476135-bit-in-sparknplug-hole/
1 hour ago, Rusty Nuts said:
Agree with GTSBoy ,Nizmo Man just got lucky I reckon. This is what I found in an engine that came in for repair.
wow and engine had survived?
I bought a borescope camera to check inside there and try once again with vacumme and if not then will do compression without plug and if not then leave it for engine to take care of it .
i just want to be on safe side
whilst on the topic, what would you put on injector oring to make it slide in and out, would wd40 damage it ?
Use an empty Vacuum cleaner with a small long hose tapped to it. L9ng so u don't drop it in and empty so u can tell when u got it.
Or rotate the engine till the exhaust valve is open and blow it out with a compressor.[emoji39]
I would attempt this method, vacuum doesn't need to be empty. just cut up a pair of the girlfriends/wifes pantyhose and use as a filter in the hose (vacuum hose not small hose)
Edited by Rusty Nuts
  • Like 1
11 hours ago, GTSBoy said:
Vaseline.  Or there is proper o-ring lube available.
10 hours ago, drifter17a said:
How would you remove it though as you can’t get vasaline there
you need something that sprays
Vaseline was to do with the question about injector o-rings.  Which I would have thought would be quite clear when I mentioned f**king o-ring lube.
As to the piece of plastic......close the engine, start it up, go on with your life.
  • Like 1
If you are turbo it will probably create a problem depending on the plastic.
If it's really soft and breaks up easy as maybe ok. But if it's a solid firm plastic don't put it through a turbo.
To many possible problems including residual melting plastic that could screw the exhaust turbine wheels performance and functionality , waste gate & seats , also for na valve seats but that would burn away eventually unless the plastic was tough enough to bend so thin (doubtfull).
If your na turn it over do the the plug out and it may shoot out plug hole.
Bah humbug.  Any plastic will melt &/or burn away within a very short time.  If it manages to make it out the exhaust while still solid and passes through the turbine at idle, precisely NOTHING will happen.  How fast do you think the turbine will be spinning at idle?
Hahaha it's not about how long the plastic lasts. It's about the risk. What if it does catch something.
If it's coil pack rubber it could be to chunky to pass without breaking down.
Initial start will move it before it burns it.
There's an about 89 % chance you can start it fine turbo.
About 99.5% if it's na.
I just think that it can come out another way risk free.
I would if stuck at this point take out the plug disconnect car (No firing up)
And crank it a few times. Then I would expect the piece to have moved out of the cylinder so it won't fry in there when started ......depending how big the piece is.
But I would probably still be vaccumming and missing the vacuum even using it while cranking with plug out.
Hehehe they are my guestemate percentages.
if were talking a piece of the porcine insulator from the spark plug - get it out and don't start the car before you clear it.
if were talking a small piece of soft plastic then meh.
if your worried about your turbo blades, remove the actuator from the exhaust flap and leave the flap wide open. the exhaust gas will take the path of least resistance and there is a verry good chance it will go out the wastegate hole not the turbine blades.
  • Like 1
Yeah, probably not.  The gas might be willing to take the left turn to go out the wastegate port, but anything solid will be more than happy to separate from the gas flow and continue going in the direction it was originally travelling - which is towards the turbine.
And I would still be fine with that.  A blown ceramic turbine is a fine excuse to upgrade the turbo, on the <1% chance that it somehow manages to break.
  • Like 1
    • Here is a recipe. Sonic blocks till you get one that has a good enough bore. Get a torque plate and block brace, use your choice of fasteners (arp ect) bolt the thing together empty, half fill it and let it cure. Release it when it has, go to a REPUTABLE RB Builder and get the thing line bored/honed and cylinder honed to size, then wash. Once its all clean and dandy, wash and blow it out again. Then again.  Assemble said engine to your desired clearances with oil control mods, gasket to suit desired CR/Squish ect. Attach your extended sump with proper trap door oil baffles and head drain plumbed to sump with a SUMP BREATHER SYSTEM. Build your front diff with a decent LSD, rebuild your transfer case with a few extra plates, more than likely replace your tailshaft centre bearing and tighten up the rear diff. Tune to minimise excessive midrange cylinder pressure (timing unless you like to split bores and rebuild engines) Enjoy your engine, but hate the fact you are now destroying engine mounts, gearboxes, gearbox mounts, diff output flanges and driveshafts, diff mounts, tailshafts and front CV's.   Disclaimer.... Ive never done any of the aforementioned stuff.......
    • 440s will support well over 400HP on petrol, which is a decent place to be for an RB20. 230+rwkW. Will be a safer bet for idle/low load. 550s would be nice for the extra headroom. I've made the same decision with mine (Neo25). 1000s are probably too big for the Nistuned ECU, so I have some smaller ones.
    • Appreciate everything guys. I did go ahead and get an alignment... most of my complains are solved. Car is not perfect, but it's good enough. If I notice uneven tire wear or anything I'll just take everything back to stock.  Thanks again!
    • They still have not shipped the 550cc injectors as they weren't in stock, so in theory I could ask to get the 440cc ones instead, if those work better in my scenario. They're the same price so really shouldn't be an issue. Unfortunately I am not so knowledgeable in most parts of tuning so I wasn't sure what's best to choose between the two. 440cc ones are the lowest they have (not in stock, but available to buy nonetheless).
