Haha one thing that I've learnt from reading all this is to get a timing light and the timing checked properly..
I've been trying to figure out what plug the tps is on the NEO but can't seem to find it. Only the suggestion it's the brown one which I don't believe it to be on the NEO.
Another thing is that when mentioning adjusting idle, that's via the screw on the iac correct?
Cheers fam.
  • Like 1
O.K
Not sure why but I am going to try and help further more
Think of the way ECU's work. Inputs tell it what is happening, ECU makes calculations and controls outputs to change the running conditions of the engine
Inputs talk to the ECU
Outputs are direction from the ECU
The CAS is an Input, so tells the ECU what is happening
When you set the base timing to 15 degrees, that is setting the BASEline for the timing, its point of reference. ECU shows input of 15 degrees
ECU fires coil packs at 15 degrees BTDC using the data obtained from the CAS. The coil packs are an output
As per above, unplugging the TPS on stock ECU is the best way to lock the timing, it is obvious when the ECU is altering the timing as you can see the timing jump around (a couple of degrees only)
If you are getting roughly double the expected value, I believe this is due to setting the timing light using the wire loop and not the plug lead method
Now think about this. Assuming your ECU is locked at 15 degrees output and is outputting signal to fire at 15 degrees, what should the input (reference) be?
A bit like your knock sensor discussion, I feel like you are overthinking it.
It's not too hard.  The throttle is in the obvious place.  The TPS is on one end of the throttle shaft and the plug is attached to that.  You'll soon know if you've got the right one.
Yes, but it is essential that the IACV is clean and working too.  If you were to wind the idle down to 650 with the IACV stuck somewhere away from bottomed out, and the weather changed a lot, the idle speed could drop a long way.  Or vice versa.
  • Like 1
  • Thanks 1
10 minutes ago, Slap said:
I thought it didnt add timming at idle
Why unplug tps?
It adds timing for idle stabilsation - I've said this before
Unplug the TPS so you can accurately set your base timing - which I've also said before
  • Like 1
And even though i was shut down and just cant explain stuff so people understand and theres lots i wanna say.. ill keep it short.
What if the ecu is fooled by setting it at 850rpm ?
Will it stay in closed loop?
Is this what a redneck like myself would call anolog tuning?
I use a narrow band emulator from the plex300te will this make an impact on idle and the o2 readings to the ecu?
I missunderstood the way electricity was manipulated by the knock sensor , now i know it is a switching current is it worth monitoring on the safc as a trace graph?
The ECU can't be fooled, it uses the CAS to determine engine RPM
2 full rotations of the crank = 1 full rotation of the CAS, i.e. it reads the home slot inside the CAS.
It's always in closed loop, until you unplug the TPS (this applies to OEM ECU only)
  • Like 1
I dont mean fooled with timing.
I mean fooled into stayin in closed loop.
By continualy forcing idle at 850rpm using the idle valve and modifying the maf signal with the safc.
1 minute ago, Slap said:
Will it then hunt timing?
If say the idle is dead at what it needs to be and the narrow band doesn't say it's too lean OR too rich (no idea what the voltage range is for the OEM Nissan ECU at stoich because I've never bothered to look), then theoretically the timing should be pretty stable, noting that the car is at operating temperature. This implies there isn't a timing compensation applied for a quick warmup strategy.
  • Like 1
Ok getting there.
Warm up isnt involved with what im discussing...atm lol (different maps).
Now my cam gears are set ex advance 7°
In retard 2-3°.
Cas corrected manualy 7°
Will the o2 readings be wrong?
Will ecu do fuel trim?
Will ecu compensate timing based on fuel trims if needed?
Car is at 850rpm. closed loop?
This is still an idle off idle maps (atm) wanting to correct?
I use a narrow band gauge on the emulator to ensure the ecu sees readings according to plx300
No, if the combustion took place - if there are slight misfires then yes
It always does, different IAT, different ambient temperature, different altitude
No, the stock ECU doesn't care
It's always on closed loop, if the closed loop conditions are met, i.e. TPS 0%, within idle RPM range, etc.
Not sure what you mean, sorry
  • Like 1
I would have thought that because of the advance on the ex cam it would make o2 rich. Because the valves are opening earlier and the burn processes has been compromised.
The car idles at 850rpm. The ecu isnt in an idle map. Does that mean my car truly isnt idling? Or is it still at an idle ?
How much can it correct +/- advance to try get back to idle map?
When your TPS position is at 0% you're essential on the zero throttle timing table like I posted up before.
I think you're understanding it differently, the car idles because it is commanded x amount on the IACV, and y amount of injection and z amount of timing.
  • Like 1
Gents,
When Slap is asking about closed loop, he's talking about closed loop fuelling.  I suspect when Johnny Dose is talking about closed loop (in above posts) he's talking about closed loop idle speed control.  So, talking at cross purposes.
As has been posted before;
At idle (ie, TPS closed, ~0.45v) the ECU is definitely in closed loop idle speed control.
At idle, provided the O2 sensor is warm enough, the ECU will be in closed loop mixture control.  But this often fails and the ECU will just revert to the idle fuelling map.
At idle, the ECU does not change timing based on O2 feedback.
At idle, the ECU adds AND subtracts timing from the base 15° according to its needs for idle speed control, but is aiming to run 15° and control speed with IACV wherever possible.
  • Like 1
  • Thanks 1
Yes i was meaning closed loop fueling.
And still. At 850rpm is my car idleing?
And no i dont care about what map its on.
And i do use an upgraded wideband o2 sensor that converts it to a narrow band reading through an output to the original o2 pin wire on the ecu.
Its 850rpm.
The idle control isnt working to its programed function due to interference.
The car will?
Was it reving at 850 or idling.
Im no professor and have learned some stuff here but have you?
Its 850rpm.
The car will?
What are you trying to learn here?
If the car is Idling too high ecu will pull timing, too low will add.
I have learnt nothing from this thread, I am also not a professor.
  • Like 1
I will now quote myself.
And thus, yes it is idling.  It is not running on the main maps.
And the original argument was whether the ECU added 15° to a static 15° for a total advance of 30°BTDC, which is not the same thing as the ECU using delta control to manipulate the idle speed.
And Slap, RB20s have an actual TP switch, not just a sensor.  Idle is a binary input to the ECU.  You can prove it to yourself.  When it is idling, as you open the throttle (by hand, with your head above the engine), very slowly, you will hear the ECU double pulse the injectors just once.  That's the ECU seeing the idle position switch input disappear, and is actually a good way to adjust the idle position switch on an RB20.
The RB25s rely on the analogue from the TPS.
  • Like 1
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
