1 hour ago, djr81 said:
Sorry to go off topic but can anyone confirm the pcv thread size and type?
http://www.kudosmotorsports.com/catalog/valve-suit-nissan-200sx-skyline-gts25-rb25de-sr20det-p-1479.html
Reminiscing about RB's
I accidentally kinked a the head vents once to my can, lots, and I mean lots, of white smoke.
Maybe the motor is breathing that heavy that it is "pressurizing" the engine because the little outlet at the filter is causing a restriction, maybe, maybe not.
I would try and strip as much oil, via a good AOS system and plumb it back to the intake to "create a vacuum" senario thingamajig in the sump.
Plus "notracecar" so "notemmisionsdefect".
Little update:
i have 3 catch cans now as follow
one 3 port 60ml baffeled and filtered which has rocker going to it on input and output goes to another catch can which is 2 liters .
2 liters breath to air and it is not baffeled or filtered
third catch can is pcv in and out to manifold
smoke has stopped and car feels much stronger, touch wood
would you put wool wire in the 2 liter one to help with filtering?
no smell no nothing and well happy
9 hours ago, drifter17a said:
Little update:
Only if you use stainless as steel will disintegrate after a while.
If ports are not marked they are presumably all the same.
Its a pity the baffled and filtered on is so small as I would consider 2L a minimum size.
I use the stainless coarse pot scourers. I wouldn't think rust would be an issue though as it is going to get coated in an oil mist.
Touch wood nothing so far
the pipe that came with moshimoto was cheap as it looked like a water hose and after little drive it heated up and car was smoking like hell
i was so annoyed until i realised that was the culprit
put a stainless steel braided and good now
only issue is the pcv valve is not fully inside the rubber gourmet and if hose is pulled or moved it moves out a little bit and that too me creates boost leak under boost as boost from manifold escaps
can i put black silicon on it?
You buy a new grommet. They are the same as many other cars, take yours to a car parts shop of your choice.
Seems a bit excessive to me.
Any oil leaks?
Only 2 ways it disapeers.
Burning (multiple cause possibilty) or leaked (seals , gaskets, filter)
Motors always burn some but when its usualy in excess can be from but not limited to ...oil passing the rings (wear , wrong gap, worn ringlands) , intake taking in oil (breather setup & pcv from blow by) , head gasket leak (doughtful) , turbo seals.
Personaly if it was 200ml per 1000miles id be thinking its fine but others may say different.
Any oil leaks?
a bit excessive? 1ml of oil per 1mile of driving....
Apologies for getting into this thread so late.
Firstly, would everyone please stop referring to this device as a "catch can", it is an "oil-air separator".
Secondly, the apparent installation is a bit iffy. Surely a simpler method:
1. Remove hose running from Ex rocker cover down to the turbo.
2. Leave hose connecting In rocker cover to Ex rocker cover
3. New hose from Ex rocker to Separator
4. New hose from Separator to turbo.
5. Stuff steel wool in Separator to act as a "seed" for the oil vapour to condense onto.
No need for a third connection on the separator - block it off.
Simplesness
Simplesness
Its a catch can unless its some how baffled at least. Read all of the thread - you will find that the vast quantity of oil requires more than a simple solution in this case - otherwise you are just pouring oil into the turbo intake.
Simplesness
thanks mate, i suppose in stage 4 you are refering to recirculating the vapor or oil into intake before turbo ?
mine is blowing to air so don't want any sh*t in my intake
only thing i have not checked is return on turbo, can leaking return line cause any blue smoke or crank pressure apart from obviously loosing oil as it returns ?
I am planning to change the gasket again in case that is the culprit as there is hardly any oil in catch can or intake pipe so can only think leaking oil from turbo, drain or sandwich plate ..
Dunno if you have already done this but get your car up to 100 or so in third gear - downhill would be better but not necessary - and then take your foot off the gas for five to eight seconds and then floor  it. Do you get a cloud of smoke out the back and if so what colour is it?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
    • Wish someone would start a racing series for Group A replica cars, a bit like Touring Car Masters but for 1985 onwards and not grandpa's falcon and/or Monaro. I know they race in some historic class but that's for original cars, no replicas allowed.
