Hi Guys,
I have a Just Jap 3" dump pipe and the Kakimoto REGU 06&R 3.5" cat back exhaust. I was wondering what to do about a hi flow cat.
The three options are 100 cell 3" hi-flow cat, 100 cell 3.5" hi-flow cat or a transition from 3" to 3.5" (no cat).
It is going in a R32 GTST with the RB20 and will be running a Hypergear ball bearing hi-flow turbo (G2 or G3 trim, not sure yet) on the standard exhaust manifold.
It will be mostly driven on the street.
Let me know what you think...
Cheers Ange
Edited by HCR32 type M
https://www.sau.com.au/forums/topic/476180-hi-flow-cat-recommendations/
I'm confused. Where are you thinking of putting the cat? The Kakimoto bolts to the dump pipe right?
If the last is true, I would put a 3" cat in the dump pipe.
How are you going to transition from 3" dump to 3.5" Kakimoto?
Edited by Silverhks
  • Confused 2
I thought the cat goes in between the dump and the Kakimoto?
I have both parts on the way, so I haven't physically seen them yet...
I'm still new to this platform. However, aftermarket dump pipes like that are usually designed to mount to the existing cat-back eliminating factory cats. If you want a hi-flow cat you then have it fabbed in as far down the dump as possible. This hurts emssions on cold starts but works just fine once warmed up while allowing the best flow for your turbo.
The specifics of this platform I could have very wrong though. I hope someone more knowledgeable will chime in soon.
Almost all dump pipes and cat backs assume the retention of a factory sized cat.
Thought 1.  100 cell cats are useless as cats.  Also not legal.  You might as well have a punched out fake cat as waste money on a 100.
Thought 2.  200 cell cats actually work.  Not as well as a proper cat, but they actually do something.  They are also not much more restrictive than a 100 cell cat.
Thought 3.  As you're only putting it on an RB20, you won't need to consider massive flow potential, so a 4" cat (rather than the more extreme 5" that people squeeze into RB25+ exhausts) will do the job.  That's a 4" cat matrix with 3" or 3.5" flanges to suit your other exhaust parts.
Thought 4.  It is very common to have to buy a cat with no flanges and get them put on to make all this shit fit together.
I will be fabricating what ever option I end up with.
So use a 200 cell 4" hi-flow cat and fab up the correct flanges to suit each end?
Essentially, yes.
As to exactly which make&model of cat to use.....I'm not sure what the cool kids are running these days.  MetalCat was cool for a while.  I think it has been Venom more lately, but that could have changed.
Our 100cpi venoms on its way from george. originally received the 5" but our GTT sits fairly low and before even trying it on it seemed like it was gonna scrape on every speed bump. so sent that back and went with the 4" instead.
quality seemed great and priced bloody well. customer service was on point too. so yeah i reckon venoms where its at these days lol
and if anyone thinks it was a mistake sending the 5" back for the 4", please lemme know haha. i've read it shouldn't be a restriction til about 250-300kw, and ours is only about 200 right now
Just a note on that, my 100 cell cat is working, and my car passed emissions with it (to the standards set by Nissan, that can be seen in the engine bay). I believe that there are bogus catalytic converters, and those that are truly working... :)
Cheers, is George on the forum or do you buy them online?
14 hours ago, Silverhks said:
See, I knew I was to new here to open my mouth. Apparently I never learn ?
At least I know better than to give legality advice...
Haha, yeah they're not like VAG or BMW.
He might be on the forums dunno. I do know he’s on eBay Australia, is on FB, has a website just google venom exhausts Australia, and also +61 402 753 146 (publicly advertised mob). He has iMessage so you should be able to text him for free if u have iOS. Dunno if he’d ship overseas but worth a shot I guess.
Tbh if we’re talking cats ur probably gonna spend a lot less just getting it done locally.
Edited by rakka
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
