Hey guys, so I'm in the middle of moving (can't start taking things apart too much because the car needs to be able to be driven to the new house).
I have a consistent light knocking sound coming from the lower timing cover. I thought it was rod knock since the knocking is consistent at idle and increases with rpms.
I used a broomstick to determine that the noise was coming from the lower timing belt cover BUT when i pushed on the cover a bit too hard, the noise sort of died down/changed (the noise changes depending on how hard you push on the cover). What do you guys think it could be? This all happened after I boosted the car to 120km/h when it was relativity cold (stupid). I'll work on the car when I'm finished moving but it's killing me not knowing if the engine is f**ked or not. Any help is appreciated.
Could be anything tbh.  Water pump, HB, belt, CAS, oil pump, idler wheel, cam wheels etc all live under there.  Could even be something loose inside the covers? You will have to strip the covers off when you can. Just too hard to diagnose otherwise...they would only be guesses.
  • Like 2
Yeah thanks for the advice mate. I've taken off the top cover so it's nothing under that one, so it's something to do with the bottom cover (which I don't think I can take off without removing the timing belt, need to move houses first). Hopefully nothing internal.
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
