Mamba make a T25 turbine housing for a full size (60mm) GT30 turbine. I am considering using one to save the expense of getting a new custom T3 steam pipe manifold, EWG, dump pipe made. Can anyone comment on the performance of these? I understand they're a compromise but it looks like the internals of the housing becomes quite large after the flange, you can tell how it's relieved  around the stud holes. I'm tight on space so a T2/T3 adapter won't work. Also thinking of using the compact T04B compressor cover (GT2871R cover). Thanks
Edited by Boosted Esky
https://www.sau.com.au/forums/topic/476192-gt30-compact-housings/
The mamba housing in question is a good unit, not a compromise and will perform no different from its T3 counterpart.
For best results in the compromises you have mentioned use a GTX based 71mm compressor. The 71mm GTX is native to a T04B in the GT28 series units so it will work.
  • Thanks 1
I have used mamba housings  in the past, but only ran into an issue with my falcon (the two i used on sr20 t28 and the rb25 gt30 hosuing seemed fine)
I ordered a 1.04 housing and fitted that up. on the dyno she was boosting quite early and droping off in the top end with to much exhaust back-pressure (pushing the gate open).
Physical size comparison vs the garret 1.04 housing, the mamba was more rear world similar size to a garret .8 housing.
i ended up switching to a garret 1.04 rear housing and the spool was back to standard xr6 amounts but it would hold a solid boost line and not blow the gate open.
just be weary of the potential for sizing mismatch.
  • Like 1
  • Thanks 1
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
