Drill into RB26 head, where?
Ok, just a safety-check before I wreck something...
Please draw on the attached image where you mean to avoid misstakes.
I'm about to fit alignment pins (2mm) to align my knock-off manifolds with the head and the gaskets, 2 per manifold will do the job. Will need to drill approximately 5mm in to the head, where will it be thick enough so I don't hit an oil or water alley?
Well.. The manifold to stud fitment leaves a lot to wish for... Hence the extra alignment idea. Guess this is a fail on the sanity check! xD
I take it as noone butchered a rb head and know where there is extra material?
Ended up finding two spots to make tiny holes, where it won't hit the head on the other side even if it sticks out some tenths! Mission accomplished, saving the last porting to some other evening... :)
Edited by K_arlstrom
Yeah but just think about it...the holes are oversize and have some movement allowance from factory. What happens when the manifold gets hot - thermal expansion movement. And you're putting in dowels to ensure the manifold no longer has any movement?
I'm all for thinking outside the box - hell i made a large box with a seat on the outside of it, just so i could sit there and think - but it doesn't sound like a good idea.
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
