Good day buddies.... So i have recently installed some Tomei Poncams(Intake 260 9.15 and Exhaust 262 9.15 lift) for my engine (RB25DET NEO).... After they were installed i never checked the shim clearance(p.s shims are above bucket type), due to it being drop in cams and my buddy who installed them never had to re-shim. Unfortunately after i started the car i heard a ticking noise from the back of the head and then investigated the reason of the noise. For a second i taught it was the body oil used(20w50) and i live in the caribbean. So i change the oil to 10w50 and the noise reduce a bit but was still there... When i pop the cam cover and check the clearances this was the results.
*Exhaust * Numbers are in "thou" reading
1.0.019
2.0.019
3.0.019
4.0.019
5.0.020
6.0.020
7.0.020
8.0.020
9.0.020
10.0.20
11.0.20 + 0.011
12.0.018 tight or 0.017
AS Tomei recommend there clearances to be .018 thou mine reads close to Nissan specs and never did any head work....  but for when i checked the clearance on valve #11 and #12 i notice that was the problem.... What can cause that such big clearance #11 and tight clearance on #12 ....Btw this is a stock head and never done any head work as my goal was to just see how long the engine can last....
https://www.sau.com.au/forums/topic/476217-valve-noise-rb25det-neo/
    • Ok, can confirm.  if you use it like a normal human being in the real world, it works fine.  it only starts crossing wires if I keep using the fob over and over again in a very short period. So if I just chill the f**k out, it works 😂😂
    • Im about to run a e30 mix of e85 and 98ron but i read that australian fuels specifically 98ron doesnt contain ethanol so on the calculator when it says pump ethanol percentage do i just put 0 or is this statement even true? And if it is true i assume i dont need to test any 98ron pumps.
    • So... the fob I had for my Skyline always had this issue where the "Unlock" button worked with no issues but the "Lock" button did nothing (and I always had to lock with the key) I thought I'd try resetting and pairing the key to the car today to see if that fixes the issue. I did the standard steps to program a key but realised my central locking was doing its own thing from time to time. 1st time: The driver-side doors would not lock or unlock when using the fob. No issues with the key. I figured it was the right time to change the battery in the fob so decided to go get one. When I went to the shop all doors locked and unlocked with the fob (while it had the old battery 🙃)   2nd time: When I locked the car, it would lock itself and immediately unlock. If I unlocked it, it would unlock and immediately lock.   3rd time:  After a bit of cursing and praying, that weird bug stopped. But then the rear passenger door started being a pain. It wouldn't really follow what the fob was asking it to do. Sometimes even using the key would not do what I wanted. So I'd lock the car with the key and all doors would lock, but the rear passenger lock didn't do anything at all. And then after a few moments, it would work again.   Is there a fuse that I should be looking at? or, is this one of those things where the door card needs to come off and some unit needs to be replaced? It just seems to happen from time to time and if I give her some space and come back later, there are no issues  🤦‍♂️ Also, should I try to program the fob again to the car just to see if that solves it?
    • One would assume a turbo is somewhere in its future down the line given they slap turbos on pretty much everything that arrives
    • I’m guess it’ll end up with a turbo
