Been sitting on residual stock and it's time to move them out. Prices excludes postage, Pick up in Sydney west, postage available unless otherwise stated. Prices negotiable, more you buy, more discount.
All parts stated "New" are old residual/leftover stock and the packaging may have dust, discoloration, opened/resealed etc. however the part itself has never been used.
Genuine Nissan:
New Genuine Nissan VQ25 Rocker Cover Gasket - Pair 13270-AL612, 13270-AQ800  $40
New Genuine Nissan R33 RB25 Series 1 Coilpack Harness Loom 24079-75T00  $200
New Genuine Nissan Windshield Dam Seal G2716-89901  $20
New Genuine Nissan RB Oil Pump Seal 15066-71L00  $10
New Genuine Nissan RWD R200 Diff Gasket - Skyline, Silvia/200SX 38320-40F02  $20
New Genuine Nissan Skyline R33 M/T, Patrol GQ Shifter Bushing 32861-01G00  $5
New Genuine Nissan Gear Shifter Socket R32, R33, R34 (ex. GTR), S13, S15 32870-V5003  $20
New Genuine Nissan Gearbox Shifter Seat Socket Snap Ring 32207-V5004  $10
New Genuine Nissan Gearbox Shifter Retaining Circlip 32204-V5003  $10
New Genuine Nissan Skyline Manual Speedo Sensor Cog Circlip   $5
New Genuine Nissan Skyline Speedo Pinion Gear Cog 32743-30P20  $30
New Genuine Nissan Skyline Manual Speedo Sensor 25010-21U00  $200
New Genuine Nissan R34 GTR Front window lower Insulator 72717-AA000  $20
New Genuine Nissan Rear Tail Light Sealing Sticky Stuff B6553-89915  $20
New Genuine Nissan CV Boot Kit 39241-73L28  $20
New Genuine Nissan PCV Seal Grommet Gasket 11812-41B00  $10
New R34 GT, GT-T Radiator Fan Shroud 21476-AA100  $80
Aftermarket Service Parts:
New Ryco Oil Filter Z145A  $10
New Penrite Racing 10 10W-40 Full Synthetic Oil   $50
New Penrite Pro Gear Full Synthetic Gear Oil 80W-140 20L drum  $250
New Gates Racing Timing Kit RB25, RB26 TCKR1040B  $150
New Ryco Air Filter - R32, R33, R34 A360  $10
New GMB Water Pump - Mitsubishi Colt - 4A90, 4A91 W3168 / GWM-91A  $50
New RB25 Lifters HL6322  $20
New Gates Racing Belt 4PK890R  $30
New Gates Racing Belt 4PK850R  $30
New Gates Racing Belt 4PK865R  $30
New Gates Belt 4PK890  $10
New Gates Belt 4PK850  $10
New Gates Belt - Suits RB26/30, 25/30 build T291  $30
New RB Gearbox Spigot Bushing   $5
New RB Magnetic Oil Sump Plug 12MM X 1.25 PSP100M  $10
New Pro-Torque RB Rear Main Seal NJ287  $15
New Single Camshaft, Crank Shaft RB Seal   $5
Newish R33, R34 Century Battery NS40ZS - Fitted to Customers car, removed 10 minutes later due to non-payment. Will provide 14 day warranty  $80
Used Skyline R34 N/A 2 Pot Brake Pads - Fitted for test drive to diagnose noise and removed   $10
New Bendix DB1220HD - Skyline R32, R33, R34 Turbo models Rear DB1220HD  $50
New Premier Brake Pads - R32, R33, R34 Turbo Models Front PR1170  $20
New NIBK Japan Brake Pads - R32, R33, R34 Turbo model Front 4 piston calipers PN7463  $40
New NIBK Japan Brake Pads - R32, R33, R34 Turbo model Rear 2 piston calipers PN7800  $30
Engine Parts:
New Permaseal MLSR Multi Layered Steel Turbo Exhaust Gasket TUR001  $15
New Permaseal MLSR Multi Layered Steel Turbo Exhaust Gasket TUR015  $30
New RB20/RB25 Turbo Gasket Set - $40
New ACL Race Bearings - RB30 Main Bearings Standard Size 7M2394H-STD  $100
New NDC Bearings - RB20, RB30 Main Bearings MS-1203GP 1.0  $50
New King Bearings - RB26 Conrod Bearings CR6697-AM 0.25MM  $50
New Skyline R33 GTS, GTS-T Round Engine Mounts Pair   $100
New Crossfire Gaskets - Valve Stem Seals RB20, RB25 - 12 pack XVSS042  $20
New ProFlow Billet Fuel Rail - RB25 PFEFRKRB25BK  $100
New Raceworks Billet Fuel Rail - RB25 ALY-029  $100
New NGK Iridium IX Spark Plugs - 6 Pack BRK6EIX  $80
New NGK Spark Plug BCPR7ES  $5
New NGK Spark Plug BKR6ES-11  $5
New NGK Spark Plug - Laser Platinum PFR5G-11  $10
Aftermarket Replacement Parts:
New Skyline R33 GTS, GTS-T Brake Master Cylinder   $50
New Skyline R33, R34 Steering Rack Ends   $40
New Mongoose M20S Alarm System M20S  $100
New Genuine Philips Xenon D2R 85126C1 single bulb  $80
Used Parts:
Used R34 Climate Control Unit   $120
Used R34 Climate Control Unit with Ambient Temp   $150
Used R34 Double Din Conversion Kit with Clarion Head Unit   $200
Used R34 Skyline Altia/Nismo front bar grille badge   $80
Used R34 Center Console Drink Holder Divider   $10
Used R34 series 2 Steering wheel airbag with "S" badge - Postage unavailable due to explosive charge.   $50
Used R34 Center Console with Rear Cup holders   $80
Used R33 Center Console (shallow type)   $50
Used R33 & R34 (Except GTR) strut brace - GReddy    $80
Used R33 & R34 (Except GTR) strut brace with Brake Master Stopper - Nismo   $80
Used R33 & R34 (Except GTR) strut brace with Brake Master Stopper - Stainless Steel   $80
Used R34 GT, GT-T Electric A/C Condenser Thermo Fan   $150
Used R32 GTS-T/GT-R Coupe Headliner - $100
Used GReddy Oil Cooler Kit - $400
  • Like 2
Updated 10:54PM, 18/03/19
Genuine Nissan:
New Genuine Nissan Gearbox Fork shifter boot to suit pull type fork (R34 Turbo pull type gearbox and maybe GTR?) - $20
New Penrite Racing 10 10W-40 Full Synthetic Oil   $50 - 1 LEFT
Engine Parts:
New Rocker Cover gasket bolt seals - $20/pack
New ARP Clutch Bolts pack - $35
New Permaseal MLSR Nissan RB20, RB25  MG3042MLSR - $60
New Mongoose M20S Alarm System M20S  $100 SOLD
New Aerpro Nissan ISO radio plug harness - $20
Used Parts:
Used R33 & R34 (Except GTR) strut brace - GReddy    $80 SOLD
Used R33 & R34 (Except GTR) strut brace with Brake Master Stopper - Stainless Steel   $80  SOLD
Used Genuine R33 GT-R 400R dual aluminium blade spoiler - $700
Used Genuine Nismo Sport Manual pedals set - $200 (have the set, just not pictured yet)
Used Genuine Impul Manual Shifter knob - $100
Used Genuine Impul Auto Shifter knob - $100
Used Genuine Skyline R34 Altia/Nismo front bar grille badge - $50
Used other badges - $10 ea.
Used Nismo clutch slave cylinder to suit R34 GT-T pull type gearbox - $50
Used Genuine GReddy Profec B Spec II Boost Controller - $200
Used Genuine HKS Speed Limit Defencer - $100
Used Skyline R33 Ignition & door lock set for coupe - $100
Used Skyline R34 Genuine OEM Fog lights - $100
Used Skyline R32 GTS-T Genuine Fog light, left - $100
Used Skyline R33 Coupe Master Door Switch, 12 pin type (good condition) - $150
Used Skyline R34 GT-T Side mount intercooler SMIC vent OEM - $50
Used Skyline R33/R34 Fire extinguisher bracket, trimmed to suit aftermarket rails - $50
Used Skyline OEM Stock Side mount intercooler - $20
Used Turbosmart dual port BOV - $200
Used Skyline R34 GT/GT-T Coupe boot carpet - $50
Used Alpha Horns - $50
  • Like 1
  • 1 month later...
  • 2 months later...
  • 11 months later...
  • 9 months later...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
