PPG or OS it still uses stock Nissan synchros. If you do go this way some of the synchro baulk rings, shift forks ect. have to be updated to the 97 -98 series 3 stuff which adds about an additional 1k in parts. OS used to do an early synchro version gearset but not anymore.
cool, no sweat then. PPG charge around $2k to do the work, so if you can get someone to do it cheaper, bonus.
26 tooth 28.5mm input shaft is still a good idea over the standard Nissan 24 tooth 25.4mm spline, and it's not an extra cost from PPG. Obviously different clutch or clutch centre hub is required though.
    • Thank you 🙏 I'm patient, which is good, considering the limited budget (for now) more so trying to understand where to begin the journey and you and the others have been good with that, appreciate everyone for their input 🫡
    • $5-10k isn't much for reliability if your looking at more power for a RB Me, with that much money currently on hand,  I would only look at things to suit future mods, as stated, a fuel pump and ecu would be my first point of call, as well as getting the injectors cleaned and tested, maybe even replace all the coolant hoses After a little time with the tuner, they should be able to tell you how your car is running in relation to things like your ignition, cooling, and other stuff that will be picked up when it has had a few runs up on the dyno and some logs to look at Basically, get everything sorted for reliability before you start leaning on a 30 year old engine Good luck with the one and only true Godzilla, enjoy Note: for your birthday presents, ask your family and friends for lottery tickets, a 32 GTR can cost "all of the money" to make reliable power
    • Strictly street. Just wanting a bit more power 🫡 Have baby seat in the back too 🤣
    • Yeah ok, it'll be expensive. But it is what it is.  How do you plan to use the car? Any track work?
    • I do have their “Nissanie Motorsports Co.” vin plates, but I am curious if anyone would have more info on them. Like how many cars they’ve imported and whatnot
