Hi Guys,
Doing a bit of a garage clean out and have a few things for sale.
Will probably add stuff as i go along and find more, but here is what i have at the moment:
Bosch Motorsport top feed 1000cc injectors. Used only for 5000kms with 98  $500
R32 GTR OEM BOV return pipe (used)  $150
R32 GTR OEM front sway bar (used)  $100
R32 GTR OEM aircon ducting (used). Every bit of plastic ducting from under the carpet and dash, except the one that goes to the drivers side vent  $50
R32 GTR OEM Twin Turbo pipe (used)  $100
R32 GTR OEM coil packs (used) $50
Ruzic II 4WD controller (used) $500
R32 carbon boot lid with carbon N1 lip and genuine R35 GTR badge. Boot lid has crazing all through the clear/resin, N1 lip is perfect, so is the badge. $500
R32 GTR series 2 textured center console surround in mint condition with lighter (used) $500
R32 GTR series 2 textured center console surround with a crack at the very bottom next to gear boot, and one broken tab at the very top $100
Sparco Sprint V fixed back seats. Pair, no rails. Very little use, some marks from storage but no tears. $500
Open to offers within reason.
Items are located just south of Wollongong.
Willing to post smaller items at buyers expense, larger items like ducting, seats and boot lid prefer pick up.
There will be more to come as I get through everything.
I will upload pics when I get a chance.
https://www.sau.com.au/forums/topic/476257-gtr-bits-and-pieces/
Also have:
Haltech I/O 12 Channel Box A only, no lead (used) $300
Haltech Can Hub Mini with 2 cables (used) $100
Haltech O2 sensor with new weld on bung, still in good condition (used) $100
R32 GTR OEM map sensor (used) $50
R32 GTR OEM Alternator (used) $100
R32 GTR OES CAS Bracket (used) $50
7 hours ago, horus83 said:
Hi Mate,
Do you still have the
Center console surround, Can you send me a pic?
I still have both. Which one were you after, the mint or cracked one?
16 hours ago, horus83 said:
If you can PM both ill decide which one? I am assuming it is the grey texture finish ones?
Yes they are both the series 2 grey textured finish ones. PM sent.
Some pics.
Ducting, Sway bar, oem map sensor, Haltech O2 sensor, Haltech I/O Expander Box A, oem cas bracket, Haltech Can Hub Mini, Injectors, Ruzic II 4WD Controller, Mint series 2 textured stereo/shifter surround.
More to come.
  • 3 weeks later...
  • 1 month later...
1 minute ago, theskidmasta said:
i know you prefer pick up,  but if you can calculate shipping to socal usa i can take the boot lid off of your hands
With the size of this thing shipping it to the states would not be worth while.
You would be better off sourcing one locally.
i cant find a decent one in the US for less than 1k AUD
Well JACKA87 is supposed to be picking it up this friday.
If he doesn't pick it up, I'll look into the shipping costs, but i know it wont be cheap and the total cost will be up around that 1k figure im pretty sure.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
