Hey,
Fitting an intercooler from an R34 GTt into my GTST. This will hopefully turn into a DIY thread once I finish. Had to stop as light got bad today..
Everything looks prety good so far, with unscrewing all the bolts and stuff.. Just wondering if anyone has some tips on removing the plastic / rubber piping from the intercooler itself? Even with the hose clamps removed it's a bit of a struggle.
BTW, I'm using the following Japanese page as a guide..
http://skyline.a-train.jp/main/ic.htm
Cheers!
razor when you are finished you should buy some sheet aluminium and make some ducting to surround it and cut a decent sized vent in the wheel arch (and mesh it if you are feeling keen) .
been there, and i hope you got it done successfully.
I have done this.
There is no real shortcut to getting the rubber piping off. It's hard but you just have to use brute strength while twisting it a little.
Good mod this one, the GTt intercooler is far superior to the R33 item.
After spending two half days working under poor light, I ended up running out of time finishing the job. The bloody piping is on so tight!
I only took my wheel & guard off so space to grip the pipes properly was limited. I'm gonna try in a couple of weeks when I have some time off work, and this time remove the front bar so I can get some proper leverage.
Guest RedLineGTR
The R34 gtt intercoler is bigger in dimensions and has a thicker core and flows better than a stock r33gtst intercooler, minimal gains but a small upgrade if you can get one for cheap. all the people i know that have installed them say its a straight fit just take your front bar off and you can easily get it off instead of trying to do it through the guard which is too much of a muck around and will take you ages.
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
