25 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Ok people It is set
Place --> Darlington Park
Date --> 04/09/04
Time --> 3:30pm
Cost --> $65
Maps are up it is exit 38 off the M1 coming down off the ramp go around under the highway & take Stanmore Rd & then travel down Stanmore Rd take Peachy Rd (left Turn) & is a little way along Peachy Rd :(
It is set so come one come all
Cheers Mike
List To Date 17/08
Oz
4 Doorz
Knore
Nexus9 (Y 4 D PARK)
Wados +1 (Y 4 D PARK)
Strutto (Y 4 D PARK)
Melv (Y 4 D PARK)
RB25
Charly
Chaos
Mick51 + 3ppl (ether D Park or Kingston)
Slamm
Lazy-Bastard (Y 4 D PARK)
Ska (Y 4 D PARK)
Maybe
Evo83 + 5
33 Niz
Nismo-Boy
Please Guys let me know if you can not make it ASAP!!!:flamed:
:rofl: Mike
https://www.sau.com.au/forums/topic/47630-go-karting/
  • Replies 132
i assume so, not the ones with two engines or whatever
they pretty quick but nothing too crazy
i used to go with a massive corporate group awhile back every few months
Most laps im just drifting though :wassup:
Had some big crashes too, none my fault :rofl:
We hold the record for most fkedup carts in one go, we wrecked 8 !
One was hardcore, my mate jake lost his front right wheel and went flying into the tyres at about 60km/h, which made the next 4-5 carts all crash aswell
ide be in for a SAUQLD gokart day
its about $60 i think for 1 practise round, and 3 x10lap races i think it is
https://www.sau.com.au/forums/topic/47630-go-karting/#findComment-961818
Hahahaha sure sure big crash was not me :(
Yeah your right with the cost it is $60 for the "Induro" witch is 1*Practise Lap 1*Qualifying Lap & then you run stints of laps with a team set up one on two in the pit wating 4 the other driver to do there set of laps, come in Kart stays running & the next driver gets in there are rules U MUST abide by other wise u get stop go's (the Marshel Calls you back into the pit :))
https://www.sau.com.au/forums/topic/47630-go-karting/#findComment-961847
Ok well as we all know we have the SAU Club Day next weekend the 08/08 (Saturday) & the following weekend slip has a skid pan day set up on the 15/08 (Sunday) so we can ether set it up for the 14th or the following weekend of the 21st of August
racing on saturday nights is till 11pm so make it about 5 in the after noon to arrive at the track
https://www.sau.com.au/forums/topic/47630-go-karting/#findComment-962328
